PDA
View Full Version : Generation III Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293
  1. Need input on PCV delete system...
  2. Help Motor Problems
  3. My new h/c setup, some questions inside
  4. best head gasket
  5. rwhp increase after break-in?...
  6. Bad lifters???
  7. Competent/Non Competent-Sponsor/Non Sponsor Tech Support???
  8. LS6 LS2 parts compatibility
  9. High idle ???
  10. Factory Rev Limit
  11. Oilling system HELP!!!!
  12. Car won't idle, stalls
  13. Biggest Cam with 59cc heads,
  14. What cam with stock heads & bolt ons M6
  15. Right Bank Misfires!!!
  16. LS1 head torque sequence
  17. oil pump recommendations
  18. T/B and intake swap
  19. wierd idel today...
  20. preping and engine.
  21. rev limiter question
  22. PC clearence question.
  23. looking for quality machine work in BAY AREA?
  24. 450+ Hp Head and Cam Package
  25. Torquer 2 guys! What heads are you running?
  26. how much power??
  27. help...
  28. What would happen if you ran pushrods that were too short?
  29. Lifter Noise on my 99 SS
  30. good Rotating Assembly?????
  31. "Troubleshooting", Chirping noise-Darton 434...
  32. Anyone use pennzoil platinum? (and piston slap question)
  33. Roll Master Double Chain with Slack
  34. LS1 heads considerations on a big bore?
  35. milling ls1 heads
  36. Biggest CAM for the streets "A4"
  37. Need help fast..question about patriot duals
  38. Question about Cam in A4 without stall
  39. Blown motor?
  40. Bore a 5.3L block?
  41. Looking for good stroked Ls1 engine builder/company
  42. What should my PTV clearance be
  43. Cam Only ???
  44. ? about porting stock heads
  45. ways to check ptv clearance?!
  46. Installed cam, having problems.
  47. Valve spring swap help
  48. The Choppy Cam Sound
  49. New cam and stall with stock 2.73 gears
  50. how do you check preload?
  51. 6.0 higher compression pistons?????
  52. Oil pump pick up tube o-ring, a thank-you to LS1Tech members & a modification
  53. Oil issues... very recent problem not sure what to do
  54. 11:1 compression to high for a daily?
  55. Why is my engine knocking / hiccuping? (Video)
  56. New Scorpion Performance Roller Rockers?
  57. Word to the Wise using Pen Magnet Method
  58. stock internal ?s
  59. Pulling engine, those in the know, how did you handle the AC compressor???
  60. main cap installation
  61. Help with my 409!
  62. crank pulley bolt
  63. Cam install starting this morning!
  64. head bolt issue
  65. smoking
  66. need some opinions on bearings...
  67. Oil Presuure Flucuating At Same Rpm?
  68. Negative PTV clearance – very unexpected on my setup
  69. couple cam questions
  70. do i need a shorter pushrods
  71. Smoke at start up.
  72. What kind of improvement do you think I would see?
  73. OTS 4.125" bore by 3.622" stroke pistons?
  74. Anybody have the tsp h/c package?
  75. Cam install questions
  76. Can someone help me with pushrod length???
  77. Important News On Bo White:
  78. Cometic gasket not fitting over dowels. WTF?
  79. who uses REAL ls6 heads?
  80. 241 heads question???
  81. MTI heads. . . .
  82. Getting timing gear off the crank snout?
  83. Am i paraniod or screwed?
  84. questions about lq4 build
  85. torquing rockers
  86. ls408 rotating assy
  87. 6.0L Rods and Pistons
  88. MS4 in a 383?
  89. i need pics of your motor with out rear cover!
  90. Question about stock crankshaft.
  91. f14 cam questions
  92. vindicator or ms4 with a 150shot
  93. casting #799
  94. 6.0L iron build
  95. New pistons in the hole
  96. LSX True Street Challenge - Oct 2007
  97. ? about porting stock heads
  98. AFR 205 head questions.
  99. Reluctor Wheels???
  100. Thoughts on this setup?
  101. my cam only gave me 4 tenths of a second..
  102. PRC 5.3 stage 2.5 heads...getting excited :)
  103. H/C Swap now consuming oil
  104. g5x3 lg cam
  105. getting ready for heads install
  106. Intake and Exhaust seat part #
  107. What Heads W/ Tr224 Cam
  108. Can 30 deg of timing destroy an engine?
  109. h/c setup, 3rd or 4th gen, which is wise?
  110. Where can I find the LSxx specs?
  111. Rod Bolts! lets get a poll going to get some actual numbers
  112. what cam?
  113. Wiring Diagram
  114. What Loctite did you use on your cam install?
  115. why are the .006" and .200" specs of a cam not advertised?
  116. Who ports heads, and how much?
  117. what is causing my power loss?
  118. Bearings for an offset crank?
  119. noticed some thing new
  120. should i check my pushrods?
  121. Looses power/ won't rev past 5500 rpm's
  122. Need some advice on top end rebuild *Look*
  123. lsx block
  124. Does anyone else have this problem
  125. cam install tool.....valve spring tool...
  126. where did u put bung for oil temp sensor?
  127. Does this gas mileage look right?
  128. Cam for a 2800lbs. car.
  129. LS1 Oil Pickup In front of sump, engine shop says it wont work, advise please
  130. Getting ready to pull short-block... what size (thread, etc..) are the head bolts???
  131. 03 ZO6 Cam and hand ported stock heads???
  132. TREX cam...is it streetable???
  133. Solid Roller worth it?
  134. Question about iron blocks
  135. cam upgrade.Worth it?
  136. Caddy Lifter Users Inside!!!!!
  137. TR230/224 and PRC LS6 CNC heads
  138. how often should I change my springs?
  139. low end torque cam?
  140. Checking oil pan-to-block clearance
  141. 1 cylinder buring oil?
  142. rough running engine
  143. TSP Magic Stick 4 Cam vs. TSP Magic Stick 3 Cam
  144. LG cams and spring life
  145. Vindicator Cam
  146. TREX/G5X4/Vindicator on stock heads? Which one?
  147. air in, air out
  148. how much slack in timing chain?
  149. valve seal problems
  150. Low power...GOT TORQUE...no
  151. Pulling motor out the top question
  152. 6.0 Engine help
  153. Will my Pistons Fit??????
  154. Pulled my vacuum lines, put breathers on, car seems to run better.
  155. adjustable timing set
  156. question about afr and trickflow
  157. 918 valvesprings prone to breaking??
  158. How much power will I be leaving on the table with my stock clutch with my H/C?
  159. brand new ls6 manifold w/ fast fuel rail kit
  160. no traction control after h/c install
  161. Technical ? about heads
  162. stupid lifter question
  163. Verified zero deck.. .040 head gaskets?
  164. Question after head and cam install
  165. Looking for 6.0L +0.030 piston supplier
  166. oh my god! FINALLY!!
  167. Pushrod Length Method
  168. What Numbers To expect With the MS3??
  169. Biggest cam I can run w/ out flycutting w/ tea heads
  170. input on a trex cam?
  171. CR and Fuel
  172. What cam will fit?
  173. Trex and heads new to ls1s
  174. 317 heads and camshaft
  175. oil question?
  176. Who runs a 370 ci iron block??......come inside.
  177. 2003 LS1 motor
  178. Smoking bad
  179. Thinking of going 408
  180. Cam suggestions for Low end tq
  181. my 226 cam with gas
  182. Valve Seals
  183. 03 Z06 AFR heads?
  184. Who makes race oil pans for an 04 GTO ?
  185. 66cc 317 heads, big cam, will this be my comp?
  186. ls1 question....
  187. need some help, motor might be on its way out
  188. 2002 WS6 engine removal
  189. Looking For Stock Ls1 Or Lq4 Crank
  190. Dude!~ Almost Done!~
  191. ported 241's
  192. having a problem with a rocker knock
  193. LS1 needs an EXORCISM! Any ideas?
  194. Heads/Cam reliability
  195. Has anyone tapped the hole for the water temp sender?
  196. Opinions, 232/236 .595/578 111+3
  197. 224/228 .600/.588 111+3
  198. ls1 valve in ls6 head?
  199. LS6 craziness
  200. stroking out to a 383
  201. help me!!!! car idles fine, till warm!!!
  202. LS6 into Fbody
  203. Pulling ls1
  204. Rebuild Options Memphis TN
  205. Can't remove cam retaining plate
  206. Is my engine F'ed??
  207. Heads AFR 225 large enough?
  208. 1.8 Harland Sharps or Scorpions???
  209. Tennis ball trick for pulling crank bolt?
  210. Pushrod/Rocker Arm Dilema
  211. How much to flycut?
  212. Porting Dart 205 Heads
  213. 93,000 miles?
  214. ppl please list mods/#'s put down w/ the trex cam.
  215. quick ? patriot lq9 stage 2 vs 3
  216. what gears for a4/T rex
  217. Show me your valve cover breather setups!
  218. Milling/decking LS1 heads
  219. Is there something missing on my engine?
  220. what happens when valve float occurs
  221. need a little educating
  222. Cam suggestion for TFS heads/402-want over 500 rwhp
  223. how much to have forged internals???
  224. Crane valve spring tool + JPR cam install tool
  225. cam question
  226. LSX Block Question
  227. 918 Spring Question
  228. budget 383 rotating assembly exist?
  229. Torque Specs
  230. tea stage 3 afrs on a 370
  231. LM7 max lift?
  232. cam and gas mileage
  233. hotcam????
  234. 370 cubic inch motor
  235. Which lifters?
  236. crane cam dual springs 99893
  237. How do recirculation pumps work? uses?
  238. Pulling motor from bottom without lift
  239. Balancing
  240. Very new to this, thinking of getting a cam
  241. Blower Cam Specs: Opinions?
  242. 98 z cracked block replace with LS2?
  243. 5.3, torquer v.2
  244. Torque on ARP head bolts?
  245. Valvetrain tap type noise since lt's installed
  246. Are PRC's .650 springs to much for a ......
  247. Engine Masters LS2 Head Dyno Test
  248. correct pushrod length?
  249. 6.0 machine work?
  250. Cam+ Heads on a budget
