- What is the difference in head casting numbers?
- need help!!!!!
- Oil Consumption
- Trex and Edelbrock Terminator heads...
- Lq4 ?
- A little help regarding Rocker arm replacement
- deleted AIR and EGR, doing heads/cam what to do?
- 98 Heads VS. 99+ heads
- Head Choices??? Experts chime in
- 02 LS6 Head Question
- QUICK QUESTION so I can figure out my DCR
- is it hard to torque the head bolts??
- took off my oil filter/pan and found this! broken? (pics)
- BIGGER ROCKER ARMS? Stock appearing LS1
- will LS2 lifter trays fit an LS1?
- Can you re-use head studs?
- Is this a good deal? h/c
- Pics of my New Canadian Performance 347!!!
- 226 cam???
- piston to valve Ok??
- Lifters solid vs. squishy & preload measurment?
- Newb question...How can I tell which block I have?
- Torquer v3 + Winter projects: DONE!
- Blow by Smoke Outta the oil cap Breather Filter
- Help me choose a cam!!!!!
- Cam change ?
- Problem with shortblock shipped, deck block?
- Southeastern US Engine builders
- stock rod with good bolts?
- Cammin' the Z06
- 98 heads (flow)
- header help quick....
- H/C ++ HOSE of NITROUS
- are all 02-04 zo6 pushrods 7.45?
- Degreeing MS3 cam
- Patriot Gold springs question.
- tsp 5.3 stg 2 heads with tsp 233/239????
- Help with Wiseco/Eagle measurements
- what is a ls4
- symptoms
- looking to buy a 408
- New piston ring ??
- Pulled motor???
- Can TTY stock headbolts be re-torqued?
- Has anyone tried the GM manifold and a carb?
- SLP Pulley + DR Timing Chain
- Almost Done Install
- What cam should i go with for a blower setup
- should I use .030 or .040" cometics?
- Dart225 Head's and Stock Rocker's
- What SCR / DCR to target for?
- Anybody happen to know the exact length of stock pushrod?
- Oil Pressure Stays up
- input needed with oil pressure issue
- ls1/ls2 valve question
- what rod length for 4.8 crank + ls2
- Questions about Head/Cam setup!
- Help Engine Assembly ?'s
- Trying to find "ignition switch hot lead"
- Please help me to verify the 2001 Z06 cam
- what will work
- Lifters
- Help! Hate to do this but I need help with
- flycutting pistons
- C5r timing cover
- Need cam position sensor connector help!
- what Lobe Seperation for a 228R??
- ms4 vs. ms3 ..
- Cam Only w 90k plus miles w stock lifters
- Do I need new Studs
- can i use green scotch brite pads and wd 40 to clean...
- adjustable rockers. What ones?
- simple head gasket question.
- Cam Help.. Newb Questions!!
- Stock heads on a TSP 228R?
- What to expect H/C LS1?...
- Head and cam install, then...
- Next Mod ???
- what heavier oil to use?
- Double timing chain with pully ?
- Head question?
- do i need to replace my cam or will li be ok
- LS1 blcok,,or LS6,,or Mutant??
- F14 installed straight up or degreed ??
- Quick question
- Are head bolts reusable?
- What diameter rod to use to hold up lifters, 1/4" or 5/16"
- ported my heads what do you think
- 383 LS1 Eagle crank and rods hitting oil pan
- How many HP stock LS1 can handle?
- Help~Head and cam combo
- Morel lifters est. ship date. ...
- compression height
- Dowel pins or Flywheel?
- locking down the flywheel
- Finally ordered my Cam Package From TSP
- Having trouble finding a LS4 oil pump?
- anyone using this?
- Confused on Head Gaskets
- GM high-flow oil pump 17801830 vs. LS4? Help, is 17801830 just an LS6 pump?
- Yellow Terra's
- Does anyone know the actual price of the LSX block?
- TR5's same as TR55's ???
- Deck Height: +.006 or -.006?
- compression
- Help me choose the right cam!!!
- Customers of HPE please read!!!
- Damage after h&c install.
- Cloyes Adjustable timing set – Used ok?
- stock 5.3L cylinder head cc?
- 918 Valve Spring Question
- I have a strange one for you
- torn between cams
- How can I tell which block I have?
- Anybody in southern Iowa or northern Missouri ? need help
- PRC 5.3 stage 2.5 VS. PRC LS6 stage 2.5 on a 228R?
- why do some cams make a whine sound?
- What kind of Hp from this combo?
- 422 stroker
- Fel-Pro head bolts any good?
- Need help ASAP!!! Motor won't turn over!
- Afr ?
- Who does the best ported LS6 heads for a 3.905 bore?
- Heads only setup?
- PRC 5.3L stage 2.5 heads, 228r cam + other goodies
- TR224 112 owners check in
- Cam choice for my application
- what size heads
- Fast 90/90 with a mild H/C set-up?
- crank question
- crane cams
- How does milling affect flow #s?
- Looking for a good set of headers to match . . .
- Help - Starter Wiring Problem
- Cam Suggestions
- Flywheel question
- Cam arrived today. Grind is off. What to do?
- LIfter gloves
- Blown Head Gasket?
- cam choice for best et ability
- whos made over 800hp on a 346ci??
- Better street cam...G5X1 or Patrick G's 228/232
- 500WHP+ N/A possible??
- Project Crazy Power is ALIVE!!!!!!!!!!!!!!!!!!!!! 1st DYNO NUMBER IS IN
- Head bolt questions, ordered wrong ones.
- Need help picking out a cam for my application!
- Pressure readings do differ from one sensor to another..
- Poll: Bore or Stroke?
- what heads with t-rex cam?
- AD Performance Stroker-kits? Anybdy heard of 'em?
- What is safe to clean heads?
- looking for a cam ....
- Anyone use a Callies Superlight Magnum XL crank??
- What size injectors and fuel pump for MS4 and 125 shot
- what size pushrods
- are rods and pistons all I need for high boost ?
- Trak cam in 402ci???
- Forged 347 missing main bolts
- think i have my H/C package picked out, second guessing my choice. opinions please.
- What should I do?
- What do you guys think?
- Small tick?
- TFS Pushrod?
- what stall?
- Doing Clay test for my cam swap, Will i need new head gaskets?
- ls6 cam question
- what is my compression?another dur dur dur question.....
- Heads milled to much
- Oil on spark plug
- Head/cam on an LS1...?
- Cam gasket?
- torque value on stock rocker arms w/ comp 918's???
- EXTRA .010 milled heads
- TR6 in a mild bolt on car? (lid/catback)
- Is there a torque spec for turning over the crank?
- Cam package. Whats ur .02
- Advice for Stock motor & tranny
- Quick oil pump question
- 243 Head cc ?
- 500hp combo?
- is a good companion !!!
- HELP!!! have 2 rounded off rocker bolts
- LS2 heads on LS1
- Valve Spring Input Please.
- What valve springs???
- what thickness shim is needed to gain the 10psi in oil pump?
- New cam, car keeps dying?
- 6.0L intake manifold to 5.3L
- Car shudders under load
- Anyone running Warhawk LS1X heads?
- Broken Valve Spring
- HP and changing lifters and rockers
- Need a quick answer
- Tr5 or tr6's??
- 528ci LS1!!!!?????
- Cam
- rocker knock
- high ratio rocker arm ??????
- Is it possible to get ONE arp stud?
- Cam lift question
- Project Crazy Power is ALIVE!!!!!!!!!!!!!!!!!!!!! Video Uploaded
- Thin Head Gasket Issues? (.020 proximity)
- G5X-1 Executive cam; Anyone running this w/o heads?
- what happened to Gomer?
- Aftermarket main caps
- Plastic timing chain guide on early LS1s
- Safety wire on cam bolts?
- Help, I need to tap the block.
- slp valvespring tool
- What intake would be better to use BBK SSI intake or LS6 intake?
- Head Bolts
- Valvetrain more noisy than normal???
- New Engine Break In Procedure?
- Started my cam swap
- how do you change the valve seals?
- Got extra money now, what do you think?
- torqueing LS1 heads?
- what cam based on this heads flow characteristics?
- Attention all magic stick owners.Got a Quick ??
- oil pan gasket question
- C5 99 Power Steering Pump Leaking Repair or Replace?
- Texas Giant sound clip ...
- pulling radiator
- Power steering pulley bolt size on f-body ls1
- Heads for F-13 cam on A4 w/ 3600 Stall?
- Melling Oil Pump
- How did you complement your G5x3?
- Head Gasket Question
- 408+stock heads=drivable???
- XER Cam card specs. vs measured results
- Have you had cop issues w/ cam,lts,ory?
- i think i have a collapsed lifter
- F13 with 918's
- budget block build question
- Problem!: Idler Pulley assembly!
- How did I do, and what do I need now?
- Building a 6.0 liter which of these heads to use?
- Bad lifter?
- Edelbrock/Lingenfelter heads.
- Installing Cam Quick Question????
- Flow numbers for stock 98 heads
- ls6 pcv conversion question
- installing QTP HV 1-3/4" long tube headers
- Heads and Cam Question(Trex)
- TEA,PRC,etc ???
- Throttle response between two LS1 cams
- piston slap
- 241 vs 243
- What to clean Block and heads with?
- Need reassurance my valvetrain noise is normal
