LS1Z28_98
10-31-2008, 03:38 PM
I know this isnt an LS1 engine, but looking for some input. I have a 305 in a 1933 Ford. My battery was old and weak, but still hanging on. I havnt started the car in months. I checked the battery connections and I had a loose terminal on the ground wire. I ended up having to replace both negative and positive terminals. I got the car turning over and I killed the battery trying to start it.
I put the battery charger on and it seemed to draw power from the battery instead of charge it
I bought a new battery
I connected the positive and then when I put the negative on it sparked. Once the connection was good, smoke started pouring from the hood. I took the negative off and found the wire from the alternator to the starter was melted to the point that the wire was seperated from the insulation. No other wires seemed damaged.
WTF happened with this new battery??
I have a suspicion the battery charger took a shit and did something in there, but does anybody have any ideas? I can only think that the charger messed up a diode in the alt.
