Stereo & Electronics - installing rear view miror with temp readout on a fbody
6-Speed Terror
11-17-2008, 11:09 PM
i was wondering if any1 had istalled a rear view mirror on a fbody i have one that came out of a 08 sierra and want to know what is needed. i know i need the ambient temp sensor, i have the schematic and shows pins to power and ground, but will it work if not connected to the bcm? schematic shows it somehow goes to bcm wondering if that is only for the onstar?
WhiteBird00
11-18-2008, 07:59 AM
Does the mirror have map/courtesy lights in it? If it does then the BCM connection is probably for controlling those lights just as it is in our cars. The f-body mirror harness has three wires - dark blue with white is courtesy light power from the BCM, white is courtesy light ground from the BCM so that it can control the theater dimming effect, and black is an ordinary ground for the map lights. You will probably have to provide an additional ignition-controlled power wire for the temp display as well as the sensor leads.
slim0035
11-24-2008, 10:44 PM
Was the theater dimming effect an option, or was it standard in all of our cars?
Benner
11-24-2008, 10:48 PM
I'd think it would be alot simpler to use the setup out of an earlier model like a 99 to 02 silverado or sierra.
bill12690
11-25-2008, 02:13 AM
all of them.. not sure exactly what year it started in though
01ssreda4
11-25-2008, 02:38 AM
so are these mirrors having external sensors and where are they mounted?
daniel6718
12-28-2008, 05:18 PM
ttt i wanna know too
i know they have a sensor mounted in front of the radio behind the headlight on truck that come with them...
tecmec
12-30-2008, 03:53 PM
Gentex (http://www.gentex.com/auto_plo_interior.html) is the company that makes these mirrors for GM. They dont sell them directly, but eBay is your friend.
They have some nice ones. Personally, I want a combo of the auto dimming, map lights, and compass (this one (http://cgi.ebay.ca/GENTEX-AUTO-DIM-MIRROR-GENK31-w-COMPASS-TEMP-MAP-LIGHTS_W0QQitemZ270317332225QQcmdZViewItemQQptZMot ors_Car_Truck_Parts_Accessories?hash=item270317332 225&_trksid=p3286.c0.m14&_trkparms=72%3A1215|66%3A2|65%3A12|39%3A1|240%3A13 18)).
You can buy them brand new, with full install kit.
WhiteBird00
12-30-2008, 04:27 PM
Gentex's official distributer is Mito Corp (http://www.mitocorp.com). You can purchase mirrors directly from them with a full factory warranty. I know because I bought one and had to return it three months later due to the auto-dimming failing - they sent a brand new mirror immediately and it has worked fine for five years now.
