Small Block & Big Block Chevy Specific - Irratic water temp? Dropping under throttle why?
CamaroKidZ28
11-21-2008, 09:23 PM
This may be a very stupid question but I couldn't find anything in the search. Weather has been cooler and i took the car for a drive last night. I noticed the water temp guage was kinda shaking a little bit for some reason, so i gave it gas to see what happens. the temp from ~185 to 150 when i went WOT. The more gas I gave it the lower the temp went instantly, even if i just revved it real quick.
What causes this? Is this a bad thing?
ZONES89RS
11-22-2008, 01:47 AM
Perhaps the gauge is sensitive to vibration as it is probably a older unit?
MrOverkill
11-22-2008, 03:55 AM
Are you running a Thermostat? I dont see it as an issue unless the temp keeps climbing under cruise......
Joshiedoom
11-22-2008, 04:15 AM
Resistance changes are volts/amps increase and decrease, otherwords I bet your alternator is causing the readings to vary.
CamaroKidZ28
11-22-2008, 02:14 PM
Idk, it has never had a problem and then the other night started doing it.
Guage is pretty new, ~2 years.
Yes has a thermostat
Thanks guys, just wanted to make sure it is not a problem that I'll regret not fixing right away.
MrOverkill
11-22-2008, 02:55 PM
If it got hot then I'd be concerned, but cooler is fine. The T-stat may be stuck open, swap it out and see if the issue continues.....
