Small Block & Big Block Chevy Specific - 92 rs 305 v8
View Full Version : 92 rs 305 v8
bowtie421
11-22-2008, 07:48 PM
my lil bro got his first v8, changed the altenator it was bad and discharging. there is still a bog/ miss, is there an idle adjustment screw or is this model done by computer, thx and help is appreciated
hyperzone
11-23-2008, 12:07 AM
What kind of intake? Carb, Throttle body injected, or tuned port injected? Those cars have a computer but, to get it tuned you have to actually swap the chip in it or whole computer as far as I know. I used to have a 91 RS with a two barrel TBI. What a dog but, it was a reliable mo-fo.
swap in an LT1 and you'll be in business.
Formula350
11-23-2008, 04:18 PM
If it's stock, it won't be carb. It's TBI in the RS. Been awhile since I really checked out a TBI throttle body, but I'm sure it still has the adjustment screw. There's lots of free/cheap mods to be done with the TBI itself. 454 TBI, 454 Injectors (can't be from the high pressure system, as they're lower # rating than stock 305/350), quarter under the fuel pressure regulator for more pressure, double-stack the injector housing gaskets to raise the housing up higher for a bit better air flow. :) Swapping in an LT1, if it's a 92-93 LT1 will only be better due to being an LT1, but it'll still be a ECM car. Any LT1 would require new wiring, and for what it seems to be (no offense bowtie) auto-newbs, not a simple task :P
ZONES89RS
11-23-2008, 08:47 PM
Probably needs a tune up if it is a used motor, i am sure it is original. The computer usually does all the work on TBI. Should be around 700 RPM or so, 850 tops when it is warming up cold.
86MCSS
11-23-2008, 10:41 PM
my friend has a 87 camaro and correct me if im wrong but i think its TBI but i kno its not carb its a 5 sp and they can get it to start but it wont stay running what should he do about this? they plan on puttin a 400 in it but it would be nice to kno wuts wrong bc i would run fine when he got it
ZONES89RS
11-24-2008, 04:58 AM
Tell them to check the fuel pressure, i have had the original setup i had when i bought my 89 RS have a bad fuel pump, it would start and then die, pump was just trash.
86MCSS
11-24-2008, 07:36 AM
ok thanks ill talk to him about it today
86MCSS
11-24-2008, 03:57 PM
he said that it was getting plenty of fuel because the short time that it did run it ran very rich....
ZONES89RS
11-24-2008, 04:27 PM
So then it might be running and the dieing with a bad pump, running rich and then starving, check pressure.
86MCSS
11-24-2008, 08:16 PM
ok he is kinda out there lol he doesnt kno like anything about cars but thinks he knows everything so he prolly wont listen but at least i could maybe pull an i told you so
jmd
11-29-2008, 08:02 PM
The throttle body has an idle set screw that you typically don't need to touch. One way to get the cover-plug out is to drill a hole and then unscrew the screw until it pushes the plug out.
Also: make sure the gasket under the TB is correct for it and isn't allowing leaks between throttle bores and other ports.
