perryrace
11-27-2008, 09:27 PM
All
Wanted to take a few minutes and thank all of you for your guidance, encouragement, tips, tricks, research, and of course a health bit of doubt that kept me going. (had to prove you wrong)
The car I am referring to is a 99 Miata with a LS1 that I have been working on for several (many) months. I have made the effort to document the build with lessons learned etc. I will soon post track footage (if the car holds up) and look forward to working through a new track car setup. The first track outing will be next weekend.
The link to the build is:
http://www.v8roadsters.net/forum/viewtopic.php?f=5&t=33
Happy to help and or refer others to the subject matter experts as you all have done for me.
To all those working on a swap and or thinking about doing a swap; Yes it is worth the hassle, yes you can put the power down, yes there is enough clearance, yes there are good kits out there, yes it can be done without a full workshop, yes it is the way every Miata should be!
Could not of got this done with out the LS Tech members THANK YOU.
Mark
Mark
