Small Block & Big Block Chevy Specific - Which piston for my build?
Top Secret
12-05-2008, 01:32 AM
I'm planning out a budget oriented 383 gen I sbc.
Bottom end is a 2 piece seal.
Crank:
http://store.summitracing.com/partdetail.asp?part=SCA-910375&autoview=sku
Going to use the stock 5.7 rod. Block will be decked to .000"
What speed pro hypereutectic piston will give me 10 or 10.5:1 compression using a steel shim gasket?
Not only am I getting overwhelmed trying to figure out the compression ratio, but I'm not sure which pistons are for 383's!
dgcustomz
12-05-2008, 02:52 PM
It depends on what compression you want and what kinda heads you're gonna use. Go through summit racing and they have kits that run as low as $350. They are speed pro pistons with coated skirts and for a little more you can get the forged pistons. You get the gaskets, rings, bearings, just about everything you need for a short block rebuild. I got a kit for my LT1 and used a forged kit and only paid under $400. I have my engine pushing 385hp to the rear wheel. Its a good kit.
Top Secret
12-05-2008, 11:36 PM
I was planning on some Dart Iron Eagles.
jmm98LS1
12-06-2008, 10:30 AM
If you are going to zero deck the block, you don't want to run a thin shim head gasket. You'll want your quench pad to be around .04", with that shim gasket your pistons will be smacking the heads. I run these -12cc pistons in my 383:
http://store.summitracing.com/partdetail.asp?part=TRW%2D8KH859CP30&autoview=sku
I run 62cc heads, zero deck and a felpro .039" gasket and that gives me ~10.4 static compression.
Top Secret
12-06-2008, 01:39 PM
Did you have your heads milled to attain the -2 cc?
Also, do you have any problems running pump gas?
