Small Block & Big Block Chevy Specific - Opinions on this power package?
WanaRace
12-13-2008, 11:57 AM
http://store.summitracing.com/partde...1&autoview=sku
Holley SysteMAX II street engine systems for small Chevy, you get top-quality components designed to work together for dramatic results. You get fully assembled Holley cylinder heads, an intake manifold, and a Lunati cam with 235°/240° duration at .050, .490/.490 in. lift, and 112° lobe separation. You also get lifters, hardened pushrods, head bolts, a double-roller timing chain and gears, and assembly lube.
Head Combo, Head Bolts, Intake, Camshaft, Lifters, Pushrods, Timing Set, Assembly Lube, Kit
goin to be put on the sbc350 in my 76 2door!
any opinionssss
1997bird
12-13-2008, 01:00 PM
If you do end up buying this kit, make sure that your piston valve reliefs will work with the 20* valve angle Holley heads.
capn smokey
12-13-2008, 06:21 PM
I think those kits are a waste of money, they say they take all the time and research out of everything but thats the part i like. You could proly spend the same money on a dif setup and end up with alot more power and have the satisfaction of saying you put the time in and built your own shit. Tell us your goals and we can proly point you in a better direction.
WanaRace
12-13-2008, 06:27 PM
im lookin to build on the sbc350 in my 76 Nova. i want about 400-450 hp, enough to run some 12s. plus i wana make a nice street/strip car
realy dont want to spend a ton of money!
1997bird
12-13-2008, 06:52 PM
Here is a better set of heads for you to look at: http://cgi.ebay.com/ebaymotors/Dart-200-Pro-1-Platinum-SBC-Aluminum-Heads-L-K-New_W0QQitemZ300280706848QQcmdZViewItemQQptZMotors _Car_Truck_Parts_Accessories?hash=item300280706848&_trksid=p4506.c0.m245&_trkparms=72%3A543%7C65%3A12%7C39%3A1%7C240%3A1318 .
Here is a better intake to look at: http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__EDELBROCK-7501-RPM-AIR-GAP-HP-INTAKE-MANIFOLD-SBC_W0QQitemZ400011814198QQadiZ2865QQadnZCarQ20Q26 Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZViewItem QQptZMotors_Car_Truck_Parts_Accessories?_trksid=p4 506.m20.l1116 .
Here is a cam & lifter kit: http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__LUNATI-SBC-268-276-VOODOO-CAM-LIFTER-KIT-60103LK_W0QQitemZ200280396127QQadiZ2865QQadnZCarQ2 0Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZView ItemQQptZMotors_Car_Truck_Parts_Accessories?hash=i tem200280396127&_trksid=p4506.c0.m245&_trkparms=72%3A543%7C65%3A12%7C39%3A1%7C240%3A1318 .
Pushrods http://cgi.ebay.com/ebaymotors/COMP-CAMS-MAGNUM-PUSHRODS-FOR-SBC-7-800-7372-16_W0QQitemZ140283389266QQcmdZViewItemQQptZMotors_ Car_Truck_Parts_Accessories?hash=item140283389266&_trksid=p4506.c0.m245&_trkparms=72%3A543%7C65%3A12%7C39%3A1%7C240%3A1318
Head bolts http://cgi.ebay.com/ebaymotors/NEW-ARP-134-3601-Head-Bolts-SB-SBC-CHEVY_W0QQitemZ190231076376QQcmdZViewItemQQptZMoto rs_Car_Truck_Parts_Accessories?_trksid=p4506.m20.l 1116
Timing chain http://cgi.ebay.com/ebaymotors/SBC-CHEVY-V8-HD-Double-Row-Timing-Chain-327-350-383-400_W0QQitemZ380087493842QQcmdZViewItemQQptZMotors _Car_Truck_Parts_Accessories?hash=item380087493842&_trksid=p4506.c0.m245&_trkparms=72%3A543%7C65%3A12%7C39%3A1%7C240%3A1318
This list of parts to look at may cost a little bit more but should be better quality parts & net you more HP.
capn smokey
12-13-2008, 07:33 PM
I would spend the extra caah and go with a roller cam, also dont run anything but a performer RPM air-gap(nothing else compares). Check out the perfoemer RPM roller cam Edelbrock makes and try to pair it with a set of either RHS or Trick Flow heads. You can easily make 470-500fwhp with that setup, I ran something real similar and it kicked ass!
ZONES89RS
12-13-2008, 08:44 PM
Without doing a 383 stroker, the 500 HP will probably not happen, but 450 is a thing to see.
I will give you my personal suggestion, spend the extra money on the roller equipment. Those Holley heads are OK, but that is it.
southern69chevy
12-13-2008, 11:40 PM
I would definitely go with the roller cam.
capn smokey
12-14-2008, 06:24 PM
In the magazine world it happens:nod: But I think 450 is an extremely easy goal, I made 432whp with a 350. Thats gotta be close to 500fwhp Zane, but I had 11.5:1 cr and all of the nicest stuff.
ZONES89RS
12-14-2008, 09:54 PM
You were using about 50 HP loss through the drive line so about 480ish. If it was a automatic 500 would be closer to the RWHP estimate. But you had allot into it, not just off the shelf parts, 500 HP at the FW with vortecs, not gonna happen.
capn smokey
12-15-2008, 07:04 PM
^Agreed, that T-56 puts the power down nicely. And yeah you wont get near 500hp with vortecs unless they are worked over alot.
WanaRace
12-17-2008, 12:09 AM
i also looked at the eldelbrok kits!
