Small Block & Big Block Chevy Specific - heads for 350 sbc
35thz28camaro
12-14-2008, 11:01 AM
what would be a good set of aluminum budget heads for a 350? we were looking at these heads, has any one used them?
http://store.summitracing.com/partdetail.asp?part=PAR%2D2181&FROM=MG
or
http://cgi.ebay.com/ebaymotors/SBC-ALUMINUM-SB-CHEVY-CYLINDER-HEADS-ANGLE-PLUG-RACE_W0QQcmdZViewItemQQcategoryZ33617QQihZ025QQite mZ380087670315QQtcZphoto
Drumer919
12-14-2008, 01:46 PM
What company makes the ebay heads? Some no name china company? I only skimmed the info. I would go for the patriots if those were my only 2 choices.
ZONES89RS
12-14-2008, 09:47 PM
I would use the patriots and day over tose junk Ebat heads...This is where you need to buy them:
https://www.patriot-performance.com/
Those Ebay heads are pro comp or something like that, they are only good if you have them ported and basically do all the extra work.
99blancoSS
12-20-2008, 05:36 AM
Talk to Shawn at Va Speed as well, he has some nice packages for sbc's
blk/slvr02ss
12-20-2008, 09:12 AM
I would use the ones from Patriot from Summit but have them checked out and cleaned up a bit just to make sure but for the price they are well worth it.
87tpita
12-21-2008, 10:39 AM
Thats a pretty good deal , personally I would opt for the 2.02/1.60 with the angled plugs instead of the straight. Its much eaisier to swap plugs and see indexing marks.
ZONES89RS
12-21-2008, 05:32 PM
So true...
wht97ws6ta
12-21-2008, 07:16 PM
3 Questions. What kinda cubes are they going on, how much power are u looking for and how hard are u gonna lean on it.
wht97ws6ta
12-21-2008, 07:29 PM
Not sure about the patriots, but i do know the procomps are made in china and are complete junk unless u have about 800 dollors of port work done to them. And even then u only have a shiny turd. The china heads come with shallow valveseats which hurts precious pressfit. They are known for droping valveseats. I wouldnt waste my money on any china heads. And i know u have heard this a million times but you are better off saving a littlewhile longer and getting some AFRs or RHS heads. You never know what you will do in the future and wind up needing better heads. Then u have lost 900 dollors only to save 400. Just remember they dont make them cheaper for no reason.
ZONES89RS
12-22-2008, 12:16 AM
So true, but the sad thing is, Scat and Eagle are imported forgings for lower ends, i just found this out. Not all China products are junk, just most.
southern69chevy
12-22-2008, 01:48 AM
+1 on the AFR heads. That's what I'm doing right now, saving for some. I wouldn't mind hitting the lottery, then I would have the motor built by new years :D But I am also going to put my motor on the crack. So really it is all in what your intentions are.
35thz28camaro
12-22-2008, 11:19 AM
this is for a friend of mine. he has a 355 with a scat rotating assembile. when he built the motor he did not have the money to built the topend so he just put what he had on it. the car is a 90 camaro with a th350 trans, 3000 stall, 373 gears, and a 125shot. now he is wanting to bulid the topend. he was thimking about the patriots with a vic jr intake, and about a 555 lift and 240@50? he has a 650 holley double pumper carb
slow trap
12-22-2008, 11:38 AM
that combo is pretty close to a setup one of my friend has except his is a 383. the dart pro1s are decent. the 215(?) runner one should be a decent performer for a 355. also the gm 200(?) cc runner fastburns perform well for what they are. i think there was a head made by i think proline that flowed decent air. those are just decent heads but all are probably still fairly inexpensive and capable of respectable hp.
ZONES89RS
12-22-2008, 04:15 PM
The Dart and GM Fastburn heads are...OK, but they are AWESOME when ported out. They have so much room for performance when they go under the knife.
wht97ws6ta
12-22-2008, 11:25 PM
You are right both scat and eagle are casted over seas. But eagle stuff is machined here in america. And is a far sight better product than Scat. Man if u only had to balance a scat crank haha. You would pick an eagle crank up and hug it every time u walked by it. Yea i wouldnt put a Scat chain on my bicycle if that was there specialty. And as far as holding up i guess they are alright. But for some reason u got to be a frigin con artist to balance one of their cranks. And its every one ive ever done to. But Scat does have a high end crank that is made here in america. But heak they cost as much as a callies. And i surly wouldnt buy a scat over any of callies cranks.
wht97ws6ta
12-22-2008, 11:44 PM
Yea like slow trap said, he would be better off putting the large port fast burns on it if hes on that tight of a budget. And assuming with his budget hes planning to run a flat tappet cam. If thats the case i would run the comp XE284. Its like 240/246 dur at .050 with 507 510 lift. That is an awsome street strip piece, and will make a small block sound like a beast. Those heads and cam with a victor jr would prolly make around 425 HP at the flywheel. And would wake da frig up with the protein shake.
ZONES89RS
12-23-2008, 01:19 AM
How acout HRC cranks? Ever done any? I have never had a problem out of Scat or Eagle. I have a scat 9000 in a stroker and it has been threw HELL.
NemeSS
12-23-2008, 02:19 AM
have used both said brands in lsx and sbc motors,
get what u pay for does not necessarily apply to everything.
eagle cranks are very popular in lsx builds, scat h beams are of excellent quality also
ZONES89RS
12-23-2008, 03:58 PM
The Scat I beams look good to me also. Mine are rated to 650 HP.
