Sponsor Group Purchases - SUPER SALE on RAPTOR SHIFT LIGHTS @ KY SPEED
marksls1ta
01-07-2009, 10:03 PM
Sale on all Raptor Single and Dual Mode Shift Lights:
PM for pricing as it is too low to advertise
Raptor Dual Mode Shift Light with Launch Feature
http://kentucky-speed.com/images/Dual%20Mode%20SHift%20Light.jpg?osCsid=f9900ba47f5 4439499c646b88f646528 (http://kentucky-speed.com/product_info.php?products_id=452&osCsid=f9900ba47f54439499c646b88f646528)
Make your launch consistent with the aid of a Raptor dual mode launch/shift light! Our newest edition of shift lights for 2008, incorporates a launch feature as well as the features in our standard shift light. This model allows the user to set a desired launch rpm, upper and lower launch limits, pulse/rev, and shift point setting. Stand alone operation!
Uses the signal to the speedometer or the Vehicle Speed Sensor Signal to determine launch or shift mode.
Example: Program the launch to 3000 rpm, +/- 200 rpm and shift point at 6200 rpm. This effectively creates a launch "window" of 2800 rpm to 3200 rpm. If the vehicle is staged (not moving) the unit enters into launch mode automatically. If the rpm is under the lower limit of 2800 rpm, the LEDs are off. If the rpm is above 3200 rpm, the LEDs flash rapidly. However, if the rpm is within 2800 rpm and 3200 rpm, the LEDs are on constant. So the user simply brings the engine rpm up until all LEDs are on. This keeps one from looking down at the tach trying to keep the tach needle to the desired launch point. After the launch, the unit automatically disables the launch mode and enables the shift mode, where it will come on at 6200 rpm in this example.
If you choose to not use the launch feature when your not at the track, simply press the program button twice within one sec to disable the launch feature. When your ready to race again, simply press the program button twice within one sec to re-enable the launch feature.
Available in four LED colors. Seven bright LEDs visible in direct sunlight. Easy wire-up: 4 wire connection. With the supplied ten foot long black cable, you don't need to add extra wiring.
RISC processor for extreme precision and easy user interface. Simply press and hold the program button to enter into program mode, where you can set the desired launch rpm, launch limits and shift point setting. The new settings are then stored in memory. Program mode 2 allows you to set the pulse/rev, etc.
Dimensions: 3.625" long x 0.75" diameter. The most compact shift light of any manufacturer! Allows you to mount it virtually anywhere within the vehicle, even in the AC vent for a hidden but effective shifting tool.
Two different style Mounting Brackets. Vinyl covers are for reducing emitted light intensity for night racing. They do not determine the color of the emitted LED light. Covers match the LED color.
**Note** Will not work on cable driven speedometers!
Raptor Digital Mini Shift Light
http://kentucky-speed.com/images/ColorChart.jpg?osCsid=f9900ba47f54439499c646b88f64 6528 (http://kentucky-speed.com/product_info.php?products_id=451&osCsid=f9900ba47f54439499c646b88f646528)
With the help of a Raptor shift light, you don't need to worry about missing a shift. You will get consistent results, shifting at the exact desired engine RPM each and every time. With the aid of a Raptor shift light, hitting the rev limiter while going down the track is a thing of the past!
Available in four LED colors. Seven bright LEDs visible in direct sunlight. Easy wire-up: power, ground and tach signal. With the supplied ten foot long black cable, you don't need to add extra wiring.
Available in four color anodized, 6061-T6 aluminum housings for extreme durability. Also available in chromed aluminum housings.
RISC processor for extreme precision and easy user interface. Simply turn the two rotary RPM switches for the desired setting, select the cylinder setting to match your vehicle and cycle the power. The new settings are then stored in memory.
Dimensions: 3.125" long x 0.75" diameter. The most compact shift light of any manufacturer! Allows you to mount it virtually anywhere within the vehicle, even in the AC vent for a hidden but effective shifting tool.
BillyBob750
01-08-2009, 12:30 AM
Mark and Bobby are great guys to deal with, and have the best prices around. Dont hesitate to check with these guys first!
FRCBobby
01-08-2009, 05:45 PM
Thanks for the interest so far guys.
BillyBob, thanks for the kind words.
marksls1ta
01-10-2009, 12:06 AM
all pm replied to.
thanks for the orders
Mark
marksls1ta
01-11-2009, 08:15 PM
dual lights are out of stock.. thanks for all the orders.
Mark@kyspeed.com
EarlSS
01-12-2009, 03:09 PM
Iwas just getting ready to order one.:bang:dual lights are out of stock.. thanks for all the orders.
Mark@kyspeed.com
FRCBobby
01-12-2009, 03:46 PM
I am awaiting a callback from Raptor to let me know how long of a wait time we will be looking for and I will update with the expected wait.
EarlSS
01-12-2009, 06:41 PM
I hope there still at the sale price when you get them in. Its one great deal.:DI am awaiting a callback from Raptor to let me know how long of a wait time we will be looking for and I will update with the expected wait.
FRCBobby
01-12-2009, 09:16 PM
We will run another sale and do the same pricing for them then.
Thanks
BoostedLT5
01-12-2009, 10:08 PM
what is the difference between single and dual mode? No launch feature?
FRCBobby
01-12-2009, 10:11 PM
Yes that is the difference.
v3nuto98
01-12-2009, 10:29 PM
what do you wire the green wire 2 so i knows the rpms?
marksls1ta
01-12-2009, 10:51 PM
you have a pm v3nuto98
thanks, mark
musicman
01-13-2009, 09:19 AM
pm sent
marksls1ta
01-13-2009, 10:38 PM
pm sent
thanks, mark@kyspeed
marksls1ta
01-22-2009, 11:17 PM
all pm's replied.
thanks, Mark@kyspeed
www.kyspeed.com
EarlSS
01-23-2009, 02:24 AM
Any word on when the duals will be back in stock? Thanks
2002redhawk
01-23-2009, 03:21 AM
pm sent :)
marksls1ta
01-29-2009, 03:38 PM
you have a pm
the duals are due back anytime.
www.kyspeed.com
mcamarols1
02-02-2009, 02:20 PM
sent you a pm marksls1ta, let me kno when you get the dual modes back in stock
marksls1ta
02-03-2009, 08:03 PM
they should be at the end of this week.
taking preorders now.
thanks, Mark@ kyspeed
www.kyspeed.com
mcamarols1
02-04-2009, 03:53 AM
order placed!! thanx
marksls1ta
02-06-2009, 10:47 PM
thanks for the orders so far. keep them coming.
thanks again, Mark @kyspeed
www.kyspeed.com
skyhighsami
02-09-2009, 05:27 AM
Please PM me a price and availablity on the 2 stage if it will work with my 98 Camaro. Thanks
marksls1ta
02-18-2009, 01:21 AM
PMs returned thanks for the orders
thanks, Mark
www.kyspeed.com
stealthws6
02-18-2009, 09:37 AM
Please pm me a price on the dual mode shift light. thanks.
ZMonte85
02-18-2009, 11:50 PM
Please PM me price on both available shift lights.
marksls1ta
02-19-2009, 08:46 PM
thanks for the orders guys
Mark
www.kyspeed.com
dschmittie1
02-23-2009, 08:02 PM
PM me the price on the dual mode shift light
00nbmz28
02-24-2009, 05:36 PM
i would like to know too please
jattgunman
02-28-2009, 12:42 AM
Send me pricing
Mean87SS
02-28-2009, 09:04 PM
Please pricing and write up how to wire a dual...
marksls1ta
03-19-2009, 10:02 PM
dual modes are in stock and ready to ship.
have red and blue ready to ship
thanks, Mark
www.kyspeed.com
GTO JIMMY
03-20-2009, 12:13 AM
PM sent
Mean87SS
03-20-2009, 12:28 AM
pricing on a dual mode...
Mssingkid
03-20-2009, 02:52 PM
Pricing here too plz
FRCBobby
03-20-2009, 03:09 PM
PM's sent.
01Red Rocket
03-20-2009, 08:13 PM
pm sent
marksls1ta
03-22-2009, 08:28 PM
pm replied to
thanks, Mark
BoostedLT5
03-23-2009, 09:04 PM
Can you pm me the price on the dual mode, i would like to place an order ASAP.
Thanks,
Anthony
marksls1ta
03-24-2009, 10:04 PM
pm sent
bmnicolosi
03-24-2009, 11:10 PM
I would like the price on a dual mode shift light also, if you don't mind pm'ing me.
thank you,
Brandon
67goatman455
03-24-2009, 11:40 PM
sent a PM for pricing on both shift lights. thanks
marksls1ta
03-28-2009, 11:58 PM
all pm replied to
thanks, Mark
www.kyspeed.com
shannon french
03-29-2009, 01:20 AM
would liek apm on a red LED loaded one.
marksls1ta
03-29-2009, 08:18 PM
you have a pm
thanks, Mark
www.kyspeed.com
rsodeputy61
03-30-2009, 10:05 PM
pm on single mode and dual mode please sir!! :)
67goatman455
03-30-2009, 11:06 PM
just got my Dual Mode Red Shift light today. Looks awesome! thanks
marksls1ta
03-31-2009, 01:11 PM
thanks for the kind words and hope to do more business with you in the future.
thanks, Mark
www.kyspeed.com
marksls1ta
04-01-2009, 12:53 AM
all pms replied
thanks, Mark
00T/AWS6
04-03-2009, 02:51 PM
Would like a PM on single and dual mode shift light in blue.
marksls1ta
04-03-2009, 03:42 PM
pm sent
thanks, Mark
b.d.d.
04-03-2009, 07:02 PM
Price for single mode (just need a light on shift points). Also I would like to know how these compare (brightness) to generic shift lights like found on a Autometer monster tachs. I want a light that makes the whole cockpit light up, not something I have to be looking for when I need my eyes on the track.
marksls1ta
04-06-2009, 08:56 PM
Thanks for the orders this weekend.
got a few duals left in stock.
thanks, Mark
www.kyspeed.com
JoshuaCole67
04-06-2009, 09:37 PM
pm me.... would like a Red dual stage shift light.. will buy ASAP
marksls1ta
04-06-2009, 11:51 PM
thanks for the order.
will go out tomorrow.
thanks, Mark
www.kyspeed.com
marksls1ta
04-12-2009, 10:42 PM
all orders are going out Monday morning.
thanks, Mark
www.kyspeed.com
bmnicolosi
04-13-2009, 05:20 PM
Excellent customer service. Ordered and recieved extra quick, cant wait to install when car is out of motor shop.
stevied916
04-13-2009, 07:19 PM
price for single?
marksls1ta
05-01-2009, 08:04 PM
got a couple left in stock.
thanks, Mark
www.kyspeed.com
2000Z28ls1
05-01-2009, 08:29 PM
I got mine in and installed no problem, thanks alot mark great deal it works great, I think im already a few tenths quicker!!!!lol
00T/AWS6
05-03-2009, 01:50 AM
yeah i forgot to update. I got my dual mode in, quick delivery pretty easy instal as well. FInally put Tick MC in and took it out on the road for some high rpm pulls and it worked like a charm. Nice and bright, thanks bunch Mark!!!
GR8GAME
05-03-2009, 04:56 AM
PM'd you. Waiting for a response.
marksls1ta
06-29-2009, 12:17 AM
all lights have shipped
thanks,
Mark
Wicked ls 1
06-29-2009, 06:19 PM
Any duals left red or yellow/ price?
marksls1ta
06-29-2009, 10:54 PM
PM sent
thanks,
Mark
www.KYSPEED.com
94Z28rag
07-02-2009, 01:55 PM
PM price for dual mode black/green, please!
marksls1ta
07-03-2009, 12:11 AM
Thanks for the order!!
Mark
www.KYSPEED.com
red90cobra
07-03-2009, 12:37 AM
can i get pricing on this please. thanks.
marksls1ta
07-12-2009, 09:22 AM
pricing sent
thanks,
Mark
www.kyspeed.com
Wdpballer46
07-12-2009, 10:17 AM
pricing please :)
marksls1ta
07-19-2009, 11:02 PM
PM sent with pricing.
thanks,
Mark
__________________
97 hawk
07-20-2009, 12:09 AM
X2 on the pricing thanks :D
EarlSS
07-20-2009, 01:18 AM
PM price for a dual mode please.
marksls1ta
08-01-2009, 11:36 PM
pricing sent
Thanks,
Mark
marksls1ta
08-04-2009, 10:23 PM
thanks for the orders!!
keep them coming
Mark
Nitroused383
08-06-2009, 06:34 AM
How much for the dual mode and how much for the standard version? Also what color housings are available?
marksls1ta
08-08-2009, 09:37 PM
pm sent
Thanks,
Mark
GTO JIMMY
08-09-2009, 04:56 AM
PM on price for mini? Would like to throw one in an ac vent.
RiceEaterZ
08-10-2009, 07:36 AM
pricing please for both models, w/ ship to 96816.
Thank You
marksls1ta
08-17-2009, 07:12 PM
Pricing sent
LS1crazy01
08-25-2009, 12:59 PM
PM pricing on dual mode yellow please!
LS1crazy01
08-25-2009, 07:06 PM
Pay Pal sent!
marksls1ta
08-25-2009, 11:14 PM
Thanks for the orders guys!!
Mark
nprather
08-26-2009, 12:10 AM
pm pricing on a dual mode blue
marksls1ta
08-30-2009, 10:44 PM
thanks,
Mark
BLACK MAMBA10
09-06-2009, 11:15 PM
can you please p.m. me a price on the duel shift light to 70517?
marksls1ta
09-09-2009, 03:50 PM
PM sent
thanks,
Mark
BakaN20
09-11-2009, 01:09 PM
Ordered :)
-Raymund
BakaN20
stupid iPhone double posting
FRCBobby
09-11-2009, 03:38 PM
Thanks for the order and your light has already shipped.
1sick'98WS6
09-15-2009, 11:28 PM
Please PM me pricing for both style lights in red.
Also include a paypal address.
Thanks
FRCBobby
09-15-2009, 11:31 PM
Pricing sent
Thanks
1sick'98WS6
09-16-2009, 12:21 AM
Ordered dual mode. I forgot to ask if it will fit in my a/c vent on my ta
marksls1ta
09-17-2009, 02:25 PM
yeah it will fit there that is where i have mine.
Thanks for the support,,
Mark
BakaN20
09-19-2009, 11:12 AM
Here is mine mounted in a 350z, not too out there, still pretty discrete and clean:
http://i48.photobucket.com/albums/f232/soldiersinx/100_0992.jpg
Thanks again!
cainsw
09-20-2009, 12:12 AM
Can you send me a price on a red duel mode? I see how it works off the speedometer and I have a question. Is there a way this work on an older car (racecar) with no speedo
marksls1ta
09-20-2009, 04:12 PM
pricing sent.
Thanks,
Mark
Bregedur
09-24-2009, 01:37 AM
Can I get the price of a red single mode shipped to 29072 please?
SiL3NtXWS6
09-24-2009, 11:18 AM
Price for single mode please
FRCBobby
09-24-2009, 04:37 PM
Pricing sent
marksls1ta
10-02-2009, 08:26 PM
Thanks for the orders guys.
Mark
1sick'98WS6
10-02-2009, 09:00 PM
I got my raptor dual mode in the mail last week... Yesterday, my dog chewed it up.
FML
marksls1ta
10-08-2009, 10:59 PM
That is no good. I have sent you a pm.
Thanks,
Mark
marksls1ta
10-10-2009, 11:52 AM
all shift light order have shipped
thanks,
Mark
dax1592
10-21-2009, 01:53 PM
Please pm me a price for the dual mode shift light...thanks
marksls1ta
10-29-2009, 09:40 PM
Pm sent with pricing
Thanks,
Mark
chavez885
10-29-2009, 09:45 PM
PM price of dual mode and mini to 73003, thank u.
davidhoe
10-30-2009, 10:09 AM
Pm price on mini shipped to 22556
Thanks David
marksls1ta
10-31-2009, 05:38 PM
Thanks for the orders!!
Mark
1sicws6
11-02-2009, 11:24 AM
Dual mode to 94580 please
FRCBobby
11-02-2009, 11:29 AM
Pricing sent, thanks for all the orders guys!!!!
marksls1ta
11-04-2009, 06:09 PM
got some more of these shipped out today.
Thanks for the support!!!
Mark
02ws666
11-04-2009, 07:02 PM
PM sent
marksls1ta
11-06-2009, 11:52 AM
Thanks for the order.
Mark
__________________
02ws666
11-09-2009, 11:27 PM
free bump!!
and just wondering how long it takes to get em shipped out?
FRCBobby
11-10-2009, 09:46 AM
Last orders have been shipping within 2 days dropshipping direct from Raptor.
Tallboy
11-10-2009, 10:15 AM
Can you pm me a price for the dual mode?
I'm from Québec, Canada, G6L 2R2
Thanks!
FRCBobby
11-10-2009, 10:28 AM
Pricing sent.
Punisher_ws7
11-10-2009, 10:33 AM
Free Bump!!!!!!!
These guys are really good people... and have my business :guns:
Thanks guys
