Stereo & Electronics - step by step guide for speaker install?
2002redhawk
01-10-2009, 09:57 PM
I got my speaker now i just hafta install it. Its the speaker behind the drivers seat. Is there a site that shows a step by step guide to install it??
vjo90rs8
01-10-2009, 10:07 PM
remove speaker grill, unbolt speaker, unhook wiring connector, installation is reverse.
wowsers
01-10-2009, 10:15 PM
zing!!
Engine_HP
01-10-2009, 10:23 PM
Wooow that FAST.
pentavolvo
01-10-2009, 10:38 PM
just fyi u know if u have monsoon system u cant really put a regular speaker back there and expect good performance
2002redhawk
01-10-2009, 10:42 PM
yea i was able to get it off. It was simpler then i thought :). Anyways the speaker had two positive conections and 2 negative connections?? y'z this?
vjo90rs8
01-10-2009, 10:50 PM
my instructions were assuming you have the proper speaker for the Trans Am Monsoon amplifier. What speaker are you currently trying to put in there, it isn't a best buy special is it? The stock speakers are 4ohm dual voice coil. If you have a 4ohm speaker you could just use one pair of wires but you will only get half the power to the speaker. I say, return the speakers and get the correct replacement.
the bazooka 6.5" subs from keeaudio.com could be a nice choice.
2002redhawk
01-10-2009, 11:01 PM
It was from best buy. Its some sony. I'm going to go ahead and get those subs from keeaudio. Once i get them how do i hook them up? Do they have two positive/negative connections on it?
vjo90rs8
01-10-2009, 11:03 PM
great decision and yes, just make sure you get the DVC subs and they will have 2 sets of + and - and will be a direct replacement.
2002redhawk
01-10-2009, 11:07 PM
The bazokka dvcs for 119? Thanks for the help man. Really appreciate it.
pentavolvo
01-11-2009, 12:04 AM
yup bazooka DVC's will have 2 sets of wires and wire right up for ya
wssix99
01-11-2009, 11:58 AM
Once you get a DVC speaker; this thread has some points for an install: http://www.ls1tech.com/forums/stereo-electronics/931445-bazooka-6-1-4-4-ohm-dvc-sail-panel-install-w-pics.html
The installation of the thread above is extreme. (Most people re-use the old wiring harness and many just use self-tapping screws to make new mounting holes.) However; you should pay special attention to the point about washers on the screws.
