Stereo & Electronics - bought a 200amp alternator and my check guages light is on
UnZFeat'd
02-25-2009, 01:34 PM
Hey, i got a new 200 amp alternator for my camaro, put it in, and now my check guages (not check engine) light keeps coming on like 1 or 2 seconds after i start the car up. Is there any way i can delete it? anyway i can drive around again without having a check guages light on? thanks
VIP1
02-25-2009, 01:53 PM
Did you look at all the gauges to see what is wrong? BTW, the "Check Gauges" light comes on if you have under 1/8 tank of gas. Are you low on fuel?
F55C6
02-25-2009, 11:52 PM
Could this be the computer sensing too much amperage and its the computer sending the signal that something is outside the preset parameters. I don't know, but its worth asking someone who might be in the know.
WhiteRhino
02-26-2009, 03:21 AM
Also make sure you didn't damage the exciter wire. It's the plug that goes into the top of the altenator. With a single red wire attached, I've seen lots of guys damage that wire and never new it was even there. It will cause the check light and your battery will not charge properly.
UnZFeat'd
02-26-2009, 01:38 PM
i thought about the gas, so i filled it up, but it still comes on. i damaged the exciter wire before, but then i replaced it, and it was fine with the regular autozone alternators as far as the check guages light, the only problem with those was they wouldnt hold up at high rpms with my fuel pump attatched, but they never threw a guage light at me. The voltage guage is at the third mark, in between the middle mark and the last 18v mark. its above where it usually is, just right after the second mark, which could be the reason the light is on, but how do i get it to go off? i know other people have had 200 amp alternators.
vjo90rs8
02-26-2009, 02:25 PM
measure the voltage, the check gauges light might be warning you that your voltage is being regulated too high. Don't try to figure out how to turn it off without knowing why it turned on in the first place.
UnZFeat'd
02-26-2009, 02:28 PM
whats the best way to go about that? i have a voltmeter, just want to know the most accurate place to check. also, what if it is charging too high? what can i do? is it going to hurt anything?
vjo90rs8
02-26-2009, 03:16 PM
Just put the voltmeter on the battery while the car is running, that should be pretty accurate, it should be around 14.4V. What model alternator did you get?
shoemike
02-26-2009, 11:16 PM
Did you upgrade your cables?
It is recommended with high amp alternators.
UnZFeat'd
02-27-2009, 02:41 AM
that might be the problem. i ordered a 2 guage battery hot to alternator wire, and have not put it on yet. I plan to do that tomorrow night, hopefully that will help as i am on the stock wires right now. Think that would be the problem?
vjo90rs8
02-27-2009, 02:46 AM
check the voltage, should only take a second...if anything, having smaller alternator wires would cause you to lose voltage because of its higher resistivity.
Blackfly
07-08-2009, 10:11 PM
Was this issue ever resolved?
What Alternator did you get?
AGRV8TD
07-09-2009, 09:52 PM
any issues with this overcharging the cars electrical system?
spy2520
07-10-2009, 10:20 AM
I doubt the wire size would cause a problem UNTIL you pull too much current through them.
actionhank99
07-12-2009, 12:33 PM
High amp alternators sometimes only deliver the extra amps when the engine is off idle, at idle they sometimes produce less - maybe computer is seeing less amps and thinks theres a problem?
