Advanced Engineering Tech - need help tuning my suspension
View Full Version : need help tuning my suspension
UFAIL
02-28-2009, 05:10 PM
all i want is the car to hook the best it can with what i have, my lanch needs to be perfect!! i have a 4000 stall, strange single adj front shocks, comp 3-way rears, umi subframe connecters, moser m9 with dbl adj torque arm and relocate bracket, midwest double adj lower control arms and 26x11.5 15 hoosier quick time pros.
i plan to set the front shocks on the loosest setting, the rears at 50/50 and the pinion angle at -2 degrees. how does that sound?
my main ? is i notice the relocation brackets on the m9 have 3 places to install the lower control arms, how do you know which hole to use? what changes when you move the lower control arms?
and to improve times what should i do next??
Old Geezer
03-01-2009, 10:41 AM
Maybe, try the drag section??
