Conversions & Hybrids - ls1/t56 into 70 LeMans
ral_fradet
03-03-2009, 09:47 PM
i started the swap a few months ago but i just got my high speed internet hooked up finally so now i can post some pics and stuff for you guys out there doing this swap. the car is a 70 LeMans sport that came with a 350 pontiac, th350 and a 10 bolt. i built the car about 5 years ago when i was about 16 so the paint and interior are all done (although the bodywork is a little sketchy) but mechanically it was a mess, i had only drove it a handfull of times in the last 3 years. so i ended up with a ls1 and T56 out of a 2000 WS6. i will be using the harness out of it as well as the seats and the brake booster. her are the pre swap pics
ral_fradet
03-04-2009, 06:37 PM
here are some pics of it being stripped apart, it was about at this time that i realized that i was probably over my head. as you can see it was decent on the outside but plenty ugly under the hood
ral_fradet
03-04-2009, 06:52 PM
heres the work i did on the firewall to fill all the unnecessary holes that were all over the place, i figure this thing isnt coming apart again any time soon so i may as well do it right.
dkota1968
03-04-2009, 07:06 PM
Looks like your moving right along on it, good luck on the whole swap
SkylarkLS1
03-04-2009, 09:00 PM
What mounts/oil pan/headers are you using for your swap?
ral_fradet
03-04-2009, 09:28 PM
i am using the brp style mounts with the f body pan and edelbrock headers. i have the motor in with the headers on and they do work with the brp mounts but how i have the engine set the first tube on the one side just barely hits the steering shaft. i dimpled the tube a bit and it should wok fine. if i had positioned the motor a little more to the one side when i drilled the mounts it probably wouldnt have been a problem. ill try to get some pics of that up this weekend
Project GatTagO
03-04-2009, 11:15 PM
Another Pontiac down the drain...LOL...Carry on!
Andrew
SkylarkLS1
03-05-2009, 05:30 AM
Yeah please do, but then again you have your body off the car. I heard the brp mounts raise your engine in front, just want to see how yours sits I am going with edelbrock plates/headers with milodon oil pan..hopefully I dont have to "dimple" anything with my conversion but its definitly dimpling my wallet, :bang:
BTW dont mean to hijack the thread, I have a ls1 S&P modified oil pan if anyone is interested, oil capacity isnt going to cut it:mad:
ral_fradet
03-09-2009, 07:31 PM
as far as im concerned the engine came out of a pontiac so im saying that its a pontiac motor haha. here are some pics of it all painted up. ill try to get the pics of it with the headers once i get my camera figured out
ral_fradet
03-10-2009, 08:01 PM
here are some pics of the headers and mounts
ral_fradet
03-10-2009, 11:32 PM
here are the pics of my tunnel mods
SkylarkLS1
03-11-2009, 01:10 AM
Damn you cut open the whole top section...is that needed or can I take out my inner aggression with a hammer and massage it?
allthrotle
03-11-2009, 01:45 PM
Looking good. What mounts did you use? are you using hedman mounts? or did you make your own?:D
ral_fradet
03-15-2009, 10:47 AM
with the style of mounts i used the tunnel needs to be cut, i raised it about 2.5 inches and i still barely clears in some places. ive heard that if you use a differnt style of mounts you dont have to do it but i find that hard to believe since the 6 speed is so bulky. i made my own brp style adapters with the tall/narrow style mounts
ral_fradet
03-16-2009, 10:06 PM
here is the brake booster out of the trans am that i modified to fit. i cut the studs off of the booster and then i got a piece of flat steel and i drilled the lemans booster bolt pattern in it and then i welded it to the TA booster and drilled the top hole through the boosters mounting pad. i hope that makes sense. i also welded the lemans booster push rod onto it with a round tube over to for reinforcement. the last picture is my line lock that ill be hooking up soon
g6t6o
03-17-2009, 07:20 AM
With the tranny/motor that high, did you have any issues with the driveline hitting the floors?
ral_fradet
03-17-2009, 08:45 PM
i dont have the driveshaft in yet but it looks like it will have lots of clearance
ral_fradet
03-17-2009, 08:57 PM
here are the pics of my computer mount job and my fuse/relay box mount job. the fuse box is one of the underhood ones from the trans am and i wired it to the harness myself. i mounted the fuse box to a bracket that attaches to the bottom of the dash and to the top of the heater control box. to mount the computer i welded four c shaped brackets and ran straps through them and across the computer. it seems to hold it pretty good. it think it will hit the glove box so i might have to cut a bit out of it. last picture shows where the wires come through the firewall, the hole will barely be visible once its all together
kst8engineer
03-18-2009, 10:44 PM
It looks like your overall plan is very similar to mine. I'm also using BRP-style mounts and Edelbrock headers for the LS1/T56 combo in my '71 Chevelle, and like you, I'm going to make use of everything I can from my '99 T/A donor car.
What size of hole did you drill in the firewall to run the harness through? Where did you get the grommet?
ral_fradet
03-21-2009, 12:44 AM
i think the hole is about 1 3/4", jut big enough for the pcm connectors to fit through one at a time. the grommet is just the one out of the donor car for the harness wires running through the firewall. i just cut out the center and made a slit in it, works good. yeah ive used alot of parts off of the T/A, seats, booster, trottle cable, underhood fuse box. the edelbrock headers are pretty nice, they hang a bit lower than i would have liked though and your going to have to dimple one of the tubes
ral_fradet
03-30-2009, 09:18 PM
here are some pics of what i did with the fuel system. i used the original fuel sender but i cut of the pickup about 3/4 inch from the top and i run a rubber line down to the in tank pump. i will probably weld a rod to it to strap the pump to so it doesnt move around. i drilled a hole in the top of the sender for the 5/16 brass elbow to fit through and i jut got a fitting that will screw on to the bottom to tighten together on the sender. i used AN tubing compression adapters on tubing to connect the sender to he corvette filter/regulator. i know i should have baffles in the tank and stuff but im low on funds right now and this setup cost me pretty much nothing and took me less than a half hour to make. ill just make sure i keep my fuel tank above 1/8 tank.
