New LS1 Owners - Newbie Tech - confused
View Full Version : confused
99ls1muscle
03-06-2009, 09:18 PM
aite so this is where im at rite now.. i just purchased a used ls6 intake without egr. so from what i hear all i need is to get a block off plate to cancel it out. now im also ordering some new long tubes this weekend and wanted to make sure that, since im blocking out the egr in the intake i dont need to get the headers with egr rite?? i could just tune it out anyways? since i have a freindly smogger around here. sorry if it doesnt make to much sence... newb
waldershrek
03-06-2009, 09:21 PM
Yes, if you get the block out plate you will be fine with the non EGR headers. Just get a tune also
99ls1muscle
03-06-2009, 09:27 PM
ok just wanted to make sure... thanks for the quick response!!
Brian M
03-06-2009, 09:28 PM
whats the block out plate i have no egr and i dont think i have a block out plate
waldershrek
03-06-2009, 09:33 PM
If your car didn't have EGR originally then you wouldn't have need for one. It is a part designed for cars that had it originally but removed it for what ever reason (usually race headers with no emissions fittings).
nemss1
03-06-2009, 10:44 PM
if anyone needs blockoff plates, speedinc and texasautocraft.com have them
99ls1muscle
03-07-2009, 02:52 PM
one more question, do i need to purchase the rear o2 extentions??
tacklebox
03-07-2009, 03:05 PM
With longtubes? Yes.
tacklebox
03-07-2009, 03:08 PM
Get the O2 extentions and use them for the fronts. Have your tuner delete the rear 02's.
99ls1muscle
03-07-2009, 03:28 PM
cool thanks alot!!
waldershrek
03-07-2009, 03:35 PM
Well the front ones the car needs to run. It uses those to determine how rich the exhaust is and adjust the fule/air/apark accordingly. The rear ones are for emissions purposes only and do not affect performance. Most guys just have the rears tuned out when using longtubes
nemss1
03-07-2009, 07:00 PM
if tuning rears out, u can plug them with oil drain plug for a toyota (18mm x 1.5 pitch). can get these at advance auto for a couple of bucks
