Cross
03-21-2009, 10:02 PM
I am looking for advice, esp if I should be asking else where and information.
I found the Granny Speed kits, 1580 for everything including AC and PS but I would like to talk to others who have done it.
Personally I think I can get some items cheaper and I think a few items should not be all that hard to make for myself. (A huge reason to ask those who have been down this road.
I would also like some other advice on the build etc.
The RX7 I bought is a GXL or GXU I forget which but the owner paid to have the harness converted to the Turbo 2 one and has the ECU to support it. I will sell the ECU obviously.
However since I want to run a SBC and a carb as well (I have access to some old Holley 650CFM's from a good friend who is helping me with this build) I really just want the Cluster and such to work so the wiring is something I would not mind some input on.
Also I was told the Rear End (He swapped it to the Turbo 2 Rearend) could handle 10 Sec passes on the T56 (I am keeping my LT1 T56 for this project) with the addition of a Pinion Snubber I believe granny's Sped called it.
Whats everyone elses input on this?
For my build I wanted to have a SBC that rev'd to a max of 8K, made peak power at around 7300RPM and was offset on HP vs Trq (Aka say 423FT Trq, 512HP) as I am still worried about putting this much Trq in a Shell that never really had to handle it. (Esp since I plan to drive this car quite often).
So advice on things I should do, motor builds is 110% Welcome!
Other than that lets start talking!
