Small Block & Big Block Chevy Specific - Who has ran a SBC with a blower @ 10-1 compression?
T/AWS6969
03-23-2009, 11:09 PM
Just curious who has done this. I have a fresh 355 with flat tops and 64cc TFS heads and am thinking about a weiand 144 or 177 on top of it. anyone done this and how long did it survive with low boost. not a forged bottom end:bang:. I am going to put this engine in my truck (it was basically free) and figure if it blows---well, it blows. Besides i have anuther block that i will be building for boost in the meantime. Thanks for responses in advance.
ZONES89RS
03-23-2009, 11:59 PM
Hope your rings are gapped out a bit, other than that, low boost? Should last a while unless you drive like me:)
T/AWS6969
03-24-2009, 12:17 AM
how low of boost should i go if i would want it to last awhile (like 2 years only driving it every weekend 4 months out of the year)?
ZONES89RS
03-24-2009, 12:59 AM
5 lbs maximum i say.
AutoRoc
03-24-2009, 01:12 AM
I bet it will work great...Let us know..:) Make sure you get premium fuel.. Aluminum heads will help it work ok... Keep the water temps down.. 160 stat? LT1 cars get away with 8psi all the time and they don't have the benefit of a carb and it's cooling effect on the fuel as it enters the engine. Then again most of those kits have intercoolers...hmmm A non aggressive ignition curve and a loose converter will make it's life a little easer also. Sounds like trial and error but what isn't.. haha
A thicker head gasket could drop compression right? or would that open up the quench too much and just make combustion worse even though compression dropped slightly? Somebody can chime in, you can't be the first! :) Goodluck.
T/AWS6969
03-24-2009, 08:44 PM
anybody else with any comments?
1997bird
03-25-2009, 04:47 AM
Has the engine been decked? What head gasket are you useing?
T/AWS6969
03-25-2009, 02:55 PM
Hey Shane how you doing?? As you can see i have a new build sice i decided to throw my cousins engine that he just had sitting in his garage while i rebuild my 391. I checked those cylinder walls on the 391 and they dont look good at all! So i decided to play with this 355 in the meantime. So to answer your question, the engine (355) has not been decked and it has the steel core Fel Pro gaskets. Thanks
1997bird
03-25-2009, 04:31 PM
It's busy (100 plus hrs. a work week) getting things done for ConocoPhillips/Energen Resourses and the kick off of the circle track race season. You should only be 9.28:1 compression with the above supplied info. With your elevation and the compression ratio you should be able to run 8-9 lbs. of boost at your elevation only! I wouldn't try to turn more than 6000 rpm with it and keep the timing conservative as well. I hope your 391 build goes well for you when your able to work on it again.
T/AWS6969
03-25-2009, 05:05 PM
Thanks so much Shane. Glad things are goin well for you with the ecomony the way it is. Where would you say i should put the timing roughly?? I dont have the cam spec right now as i am at work. I will let you know later. thanks again man!
1997bird
03-25-2009, 05:24 PM
I would keep your total timing to 28-30 degree's, from there you will want to monitor you spark plug color to tune your carb to match.
T/AWS6969
03-25-2009, 05:36 PM
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=202&sb=2 link for the cam i am also installing 1.6 ratio roller rockers
1997bird
03-25-2009, 09:52 PM
That cam should put you perfectly in your rpm limit with the stock rods.
T/AWS6969
03-25-2009, 10:42 PM
Sweet! thanks!!!
speedy55
03-30-2009, 09:26 PM
You could always add a methanol injection kit from snow performance to come on when the boost come up. That would cover your fuel concerns.
