Small Block & Big Block Chevy Specific - Throttle cable setup for SBC in 4th gen?
southerntp
03-25-2009, 08:50 PM
I have put a 421ci SBC into a 2000 camaro, stock suspension car to run ORSCA modified street. I have almost everything planned out perfectly except for the throttle cable setup. What are most of you guys running to make this work? Please list make and part numbers if possible. Oh yeah, I am going to be running a 4500 dominator carb. Thanks in advance
ZONES89RS
03-25-2009, 09:06 PM
I stole that cable out of a third gen on my 95 Z. Has to be a TBI V8 car or a original carb equipped ride.
southerntp
03-25-2009, 09:13 PM
what carb are you running?
southerntp
03-27-2009, 06:58 AM
come on guys help me out here. I need to get these parts ordered as soon as possible. I need your help.
raped 95Z
03-27-2009, 09:04 AM
just buy a universal cut to fit steel braided one from LOKAR they are tit to install....
Schwanke Engines
03-27-2009, 10:29 AM
Ditto on the Lokar cable. We have them if you need one overnight.
xx_ED_xx
03-27-2009, 11:24 AM
Pick up an issue of street rodder. They have all kinds of neat custom stuff
ZONES89RS
03-27-2009, 01:01 PM
I am running a holley 750.
southerntp
03-27-2009, 01:40 PM
do you have a part number on the lokar cable? Also any other mounts that I will need. List all part numbers needed for all of the mounts, brackets, etc. Going from stock to this. Thanks
ZONES89RS
03-27-2009, 07:13 PM
I used the random carb throttle linkage mount from the parts house performance wall.
southerntp
03-28-2009, 09:32 PM
any part numbers or places that I can buy them at?
ZONES89RS
03-28-2009, 09:49 PM
I cannot remember the part number, it was on the wall at Oreilly. I will see if i can get it when i stop by again.
southerntp
03-28-2009, 10:51 PM
Alright man thanks alot.
nubby1
03-30-2009, 11:35 AM
i have the same set up in my 01 ws6 i went with the lokart cable dont have the part # but it was a universal cut to fit
southerntp
03-30-2009, 03:58 PM
Did it come with mounting bracket and everything? Just want to make sure that once I order this cable, that it will be the only thing that I will need to make this work. That includes bracket, and clips, and everything. Thanks
Schwanke Engines
04-03-2009, 09:41 AM
You will need one of these, http://lokar.com/product-descriptions/srk4000.htm, and one of these, http://lokar.com/product-descriptions/polished-hitech-throtcables.htm, the part number is TCP-1000HT36 36" Polished Hi-Tech Throttle Cable.
Hope this helps, if you need to order it, I can get it for you.
