Quick Time
03-30-2009, 02:17 PM
We would like to introduce our Quick Time Performance Oval Low Profile Exhaust Cutouts!
http://www.quicktimeperformance.com/OVAL/images/srt_banner.jpg
A new low profile electric cutout designed for applications that have limited ground clearance.
With the Quick Time Electric Cutout you can have the best of both worlds! Quiet for the street and wide open for the strip. Go from stealth quiet to wide open power and experience the gains even if your already enjoying an aftermarket exhaust system. You control the volume, you control the power. Open your exhaust with the flip of a switch. Run it closed, run it all the way open or any position in between.
http://www.quicktimeperformance.com/OVAL/lightbox/photos/shot1.jpg
http://www.quicktimeperformance.com/OVAL/lightbox/photos/shot2.jpg
2006 Dodge Charger R/T
Specs
-Fits 2 1/4" to 3" round exhaust pipe.
-Low profile design
-CNC 6061 Aircraft Aluminum Body
-Stainless Steel Butterfly Plate and Shaft
-6061 Aircraft Aluminum Motor Plate
-High Torque DC Gear Driven Motor (1 1/2 Ft lbs TQ)
-Custom Illuminated Toggle Switch or Optional Controller
-Weather Proof Connector w/gold plated contacts
-Made In the USA
Parts Include
-Oval Electric Valve
-Intermediate Wire
-Standard Toggle Switch
-Layered Gasket
-Oval Connection Pipe
-Block Off Plate
-4 Nuts and Bolts
-Turn Down Optional
QTEC33-Single Oval Electric Valve and Oval Connection Pipe -$185.00 Racernet
QTEC66-Dual Oval Electric Valves and Oval Connection Pipes-$365.00 Racernet
11338 Oval Turndown-$20.00 Each Racernet
http://quicktimeperformance.com/Media/ChargerOvalweb.jpg
Gains over an aftermarket exhaust
2006 Dodge Charger R/T 11hp and 12tq
For more info on the Ovals go to the Oval Page on our site.
http://www.quicktimeperformance.com/OVAL/index.php
We have 2 videos on a Dodge Charger R/T on the Oval Page. One a basic open vs close and the other a little fun with music.
Have Fun.
Keep it loud!
Specs
-Low profile design
-Made In the USA
Parts Include
-Intermediate Wire
-Layered Gasket
-Block Off Plate
-4 Nuts and Bolts
-Turn Down Optional
Have Fun.
Keep it loud!
