93c4black
04-06-2009, 09:31 AM
this is on dads ls1.. If you jump start it with another car it will start and run and show 14 volts at the alternator and 14 volts at the battery but when you disconnect the other car from it, it only shows 13 volts and it will run's intell you turn on the lights or any other power draw occurs, then it will not start back up without hooking the jumper cables back up.
have had alternator checked twice and it has tested good both times
also battery is brand new.
