Small Block & Big Block Chevy Specific - Airplane Gas????
View Full Version : Airplane Gas????
1994t/a
04-07-2009, 10:51 PM
So can anyone tell me if running a 10:1 350 on a steady diet of 100LL avgas will hurt it in the long run?Avgas does have lead in it and i was curious if the lead would build up and cause damage to the engine?I work a an airport and basicly can get all i want for free :D
2nd3rd4thgen
04-07-2009, 10:56 PM
yeah i have a friend with a 78 nova that has the same set up, and he wants to know if it will hurt his motor as well.
badjuju342
04-07-2009, 11:14 PM
I would think if you are not running cats or 02 sensors , probably wouldn't hurt anything . Lead was used as a lubricant in the older engines requiring leaded gas. One thing that has been said by some racers to me is avgas is not as good as racing fuel because it has de-icer that knocks down the octane rating . I don't know how much truth there is to that.:confused:
1997bird
04-08-2009, 03:00 AM
The local 100 octane low-lead AV gas that we have been useing tested to have a higher octane than the Sunoco 115 race fuel by a fuel density tester that we have for testing the local circle track racers.
slvr98camaro
04-08-2009, 07:44 AM
you can run it.. but you are wasting your time and money with only 10:1 compression
2nd3rd4thgen
04-08-2009, 08:47 AM
how is he wasting his time or money he gets it for free.
pancherj
04-08-2009, 10:40 AM
AV gas is rated as a MINIMUM octane. It will generally test much higher than that (the suppliers play it safe). I remember reading somewhere that it wont produce as much power as race gas because it is formulated for high altitude flying. I ran it in my 12:1 406for a couple of years with no problems.
xx_ED_xx
04-08-2009, 11:25 AM
Yeah, i wouldnt run it in a 10 - 1 motor.
moge11
04-08-2009, 11:35 AM
x3....No reason...but wont hurt it. A couple guys around here have used it for years.
1994t/a
04-08-2009, 12:04 PM
Well all i was wanting to know is if it would hurt it to run it all the time.I have noticed that it starts up easier with the avgas and runs much smoother than on 93 auto gas....as i said i can get it for free and i know it will run just fine on 93 octane,but hey if its free why not?!
raped 95Z
04-08-2009, 01:32 PM
totally un-necessary. 10.1 is pump gas friendly lllll day long. higher octance just burns slower to keep your pistons cool and help prevent detonation. i wouldnt waste your time. or you could get the fuel free. sell it by the barrell to the local ricers and tell them its the cool thing to do. then pay for pump gas =)
2nd3rd4thgen
04-08-2009, 10:19 PM
it would be wasting his time if he went to all the trouble selling it to ricers and then taking the money and buying 93 when he could just put it into his car and save himself alot of trouble. i know he doesnt need it for his car , but thats not what he wanted to know he wanted to know if it would hurt his motor running it.cuz he can get it for free and i guess he is getting it pretty easy with him working at a airport and all. :D
ZONES89RS
04-09-2009, 02:46 AM
I would use the hell out of it if i was spraying the engine.
xx_ED_xx
04-09-2009, 10:07 AM
Well for what it is worth. I had an 11-1 355 mild cam with mondo duration. 2500 stall th350 and 4.11's besides the white deposits it left on the plugs and the higher rpm stutter. that was on an av gas mix. When i ran straight 92 (mainly because that is the octane they had) Those problems were not there and it ran much better. gasoline is rated the research and motor way av gas is not. So if you like your car to not run as good sure go for it.
FrkEBz06
04-09-2009, 10:23 AM
Nah it shouldnt hurt a thing. That av gas is more similar in quality wise as gas ur 98 oct back in the 60s, thats why there were so many engines with 11:1-12.5:1 compression back then. They remove lead from gas nowadays cause of the epa crap :eyes:
stroker_SS
04-10-2009, 02:37 PM
It doesn't matter long term, as he won't be able to get it for more than a few years. Rumor has it that EPA is illegalizing the use of Leaded fuels in aviation.
Reasoning is not many new planes require leaded fuels anyway and some people with recip engines have already got Supplemental Type Certs. to run auto gas anyway. The only planes that still need leaded fuel's are the WWII warbirds and earlier using 2800cid+ supercharged radial engines. Those planes doing airshows and such will probably end up using racing gas after this law takes effect.
1994t/a
04-10-2009, 04:22 PM
yeah that is very true stroker ss....the EPA is gonna make the aviation industry use a diffrent fuel for piston engine aircraft.I refuel aircraft and i see alot of the aircraft with lower performance and low compression engines with STC's for mogas...the aviation fuel industry is already looking for a replacement.they actually are looking towards developing a new fuel thats very simliar to racing fuel but they having to get the other additives to blend with it for aircraft use......but until the im gonna run all the 100LL i can get.
STREETRODZ1
04-12-2009, 11:07 PM
The av-gas will be fine, it burns a little dryer, so to remedy that issue i put a little Marvel Mystery oil in it, just enough to tint the color of the gas. I have run it for years with no adverse effects, and it does even better with the addition of the oil. Any motor can use a little extra octane in my opinion, even if it don't neccessarily need it, it sure cant hurt.
1 FMF
04-17-2009, 06:43 PM
http://www.idavette.net/hib/fuel/page2.htm
a steady diet will kill the catalytic converters and ruin the O2 sensors. So if your engine does not have those then you aren't really going to hurt anything. But if you're fuel injected and the computer runs in closed loop mode off O2 sensors you will get major performance problems when the O2's fail.
STREETRODZ1
04-17-2009, 10:17 PM
Very true on the converters and o2s, i am speeking from more of a carburated perspective.
speedy55
05-10-2009, 09:57 PM
NO! we tried that with a big shot kit and damn near killed the car. When we hit the button it shut the car off almost and when it did ignite the mufflers looked like watermelons!We went back to spraying on 93 octane.It is formulated with de-icer for high altitude operation and even though the octane is higher it responds differently.
blubyou02
05-14-2009, 07:14 PM
AV gas is designed to burn at 10,000 feet and above, you wont see any benefit with it, and probably get a lean condition since there is more air down this low
stroker_SS
05-25-2009, 09:20 PM
No problem with lean conditions, there are many unpressurized low altitude aircraft running 100LL. The main problem lies within the tetraethyl lead and it's tendency to cause valve sticking. I would not suggest running it unless it was absolutely necessary.
1994t/a
05-26-2009, 10:03 PM
im thinking about giving it a try but just mixing some marvel mystery oil in with it....ppl ive talked to say that will stop the lead build up in the engine.guess ill try it for a lil while and see how the plugs look after awhile:confused:
stroker_SS
05-29-2009, 11:55 AM
IF you're going to run AVGAS and want your engine to live i suggest this, Marvel probably won't help much(better for carbon deposits)
http://www.aircraftspruce.com/menus/ap/fuel_additives.html
IDK it just doesn't seem worth it to me, you may run into problems with lead fowling of the spark plugs, valve sticking,and lead deposits can form hot spots which can cause preiginition(ironic huh).
