Stereo & Electronics - Finished A4 to M6 swap
View Full Version : Finished A4 to M6 swap
bene
04-09-2009, 10:42 PM
Now my cruise control doesn't work? Help?
Black02SLPSS
04-09-2009, 11:34 PM
Ya mine doesnt work either. If you want it to work then your gonna hafta tap into the pcm and run a wire somewhere, not sure where tho
bene
04-10-2009, 08:23 AM
Harness was modified for M6.
JayBirdWs6
04-10-2009, 08:31 AM
mine never worked after the install about 2-3 yrs ago either. I wasnt to worried about it
Engine_HP
04-10-2009, 03:17 PM
mine did the same thing but im still with the a4`s harness with minor upgrades.
u might need to wire the clutch pedal position switch
start by reading from here: http://www.ls1tech.com/forums/manual-transmission/200480-m6-a4-a4-m6-conversion-info-requested-25.html
Mike454SS
04-11-2009, 05:53 PM
I believe you need to wire the park/neutral switch from the auto shifter to the clutch pedal switch on the top, not the starter switch on the bottom...that way the cruise knows when you step on the clutch pedal and lets the throttle go before the engine winds up revving free...right now the cruise module is probably looking for that and seeing that it's in park/neutral, and not turning on in the first place.
I'd go nuts without the cruise, so if I can do anything to help I will...let me know if you need me to actually look at how the clutch pedal is wired in my car.
bene
04-11-2009, 09:12 PM
Hey thanks for the responses guys. Figured out why it didn't work. It wasn't plugged all the way in. So its good to go.
