slamminjim
04-10-2009, 04:49 PM
the car has a brand new motor with 3200 miles its a crate engine from ford racing the gt40x it has the edelbrock victor efi intake 30lbs injectors ford racing gt40x aluminum heads, ford racing e303 cam, ford racing headers, has msd 6al ignition box, forged rotating assembly, built 5 speed new king cobra clutch, steeda triax short throw, 80mm mass air, weld draglights wheels.
It has 125 shot wet kit on it. ac and heater has been deleted
it hasn't been sprayed yet. has weld wheels with nitto 555rs on the back.
headers and single chamber flows with a h pipe with 2 cut outs
might be some things im forgetting
I am asking $7,000 OBO
send me a pm if you have any questions
This is the info from Summit Racing
Brand: Ford Racing
Product Line: Ford Racing Boss 340 HP Crate Engines
Part Type: Crate Engines
Part Number: FMS-M-6007-X302E
Engine Assembly Style: Long block
Assembled: Yes
Engine Balance: External
Balance Style: 50 oz. imbalance
Intake Manifold Included: No
Cylinder Heads Included: Yes
Carburetor Included: No
Distributor Included: No
Oil Pan Included: Yes
Valve Covers Included: Yes
Timing Cover Included: Yes
Water Pump Included: Yes
Harmonic Balancer Included: Yes
Flexplate Included: No
Flywheel Included: Yes
Air Cleaner Included: No
Spark Plugs Included: No
Spark Plug Wires Included: No
Computer Included: No
Wiring Harness Included: No
Rear Main Seal Style: 1-piece
Quantity: Sold individually.
CRATE ENGINE
Check to make sure this part fits your application More horsepower for your Ford.
These Ford Racing Boss 340 HP crate engines feature race-quality components at entry-level pricing.
Engines include:
* Ford Racing Boss 4-bolt main block
* Forged steel crankshaft
* Forged steel connecting rods
* Forged pistons with 9.0:1 compression ratio
* Hydraulic roller E303 camshaft
* Double roller timing chain
* Rear sump oil pan
* Ford Racing GT-40 aluminum cylinder heads with 1.94 in. intake valves and 1.54 in. exhaust valves
* Roller rocker arms
* Reverse rotation water pump
* Timing chain cover
* Fuel pump eccentric
* Valve covers
* 157-tooth flywheel
http://img136.imageshack.us/img136/7592/28672208.th.jpg (http://img136.imageshack.us/img136/7592/28672208.jpg)
http://tinypic.com/view.php?pic=2iwabgo&s=5
http://tinypic.com/view.php?pic=6ibhgx&s=5
http://tinypic.com/view.php?pic=2iupoj&s=5
http://tinypic.com/view.php?pic=2ai4v4o&s=5
Brand: Ford Racing
Assembled: Yes
CRATE ENGINE
Engines include:
* Rear sump oil pan
* Valve covers
