10 Second Club - could i pull 10's with this setup?
nastychevelle
04-12-2009, 09:06 PM
94 camaro
bmr tubular k member (stock control arms)
good shocks (maybe qa1's)
adjustable TQ arm
subframe connectors
10.5" wide ET streets
5.3
218/224 .550/.550 114 cam
ls6 springs
TSP pushrods
ARP rod bolts
ported TB
ls1 intake maybe switch to a ls6 sooner or later)
1 3/4" LT's
pypes X pipe with cutouts built in through Dynomax bullets
150 wet shot with progressive controller
TH350 with shift kit and 3500 stall
10bolt with 3.73 gears
is it possible?
or better question will it beat a 05/06 gto m6 with cam and boltons
holley505
04-13-2009, 02:10 PM
depends on weight of your car.... and how well you hook. 1.5 or less 60ft times and less than 3100 lbs on the GAS (150 shot)... I say YES!!!
