Small Block & Big Block Chevy Specific - white smoke
View Full Version : white smoke
lifeisgood
04-16-2009, 12:54 PM
i have white smoke after a new set of lifters went in.
is coolant the only thing that could cause this?
i torque the manifold down in sequence at the proper torque spec.
i dont believe its the intake leaking, i ve done so many of these.
but what else could it be.
its a full size chevy with 168k miles on it. stock
ZONES89RS
04-16-2009, 02:00 PM
So, this is initial start up or it constantly does this now?
lifeisgood
04-18-2009, 01:40 AM
i thought it was constant, after a test drive it was still doing it but upon start up now it has chilled out quiet abit
ZONES89RS
04-18-2009, 02:37 AM
Valve seals could be he culprit.
irocz2173
04-23-2009, 10:15 PM
why are you thinking valve seals? that would be blue.
I would suggest checking the oil and making sure you havent made a milkshake. Really there are only a few things that could have happened,
1. head gasket blown
2. intake gasket bad (either not seated properly or torn)
3. crack in a coolant passage.
Is it better/worse when warm?
Give us more info
