Small Block & Big Block Chevy Specific - Crankshaft Strength
View Full Version : Crankshaft Strength
D79
04-28-2009, 08:27 PM
I am building a sbc for my 2nd gen f-body. The motor will be putting out 500ish to the crank and seeing 6500 rpm off the bottle.
my question is will a steel crankshaft hold up to that kind of horsepower? is a forged crankshaft in my future?
ive just read and heard many different things and wanted your opinion. :bang:
thanks everyone
kenSS
04-28-2009, 10:07 PM
if your only spinning 6500 rpms and about 500 hp, then a scat cast crank will be fine. anymore than that or spraying i would recommend a forged piece.
D79
04-28-2009, 10:14 PM
thats what i was afraid of.
i do plan on putting it on the spray down the line. just trying to save money.
oh well
kenSS
04-28-2009, 10:28 PM
i have built 600 hp motors N/A with cast cranks. i would recommend a forged one though. you will be better off down the road.
ZONES89RS
04-29-2009, 02:38 AM
Friend and i have put together a 406 that spun 6800 RPM and had a 200 shot with a scat cast 9000 piece, lasted a while till the balancer snout broke off.
D79
04-29-2009, 04:18 AM
this is where the dilemma takes place. steel cranks say around 500 ponies max. some say it wont hold. some tell me things like you just did and persuade me.
i know you are very knowledgeable on these kind of things. i know that 406 was laying down more than 500 horse.
how long did the crank last?
i need this build to last me a while
pancherj
04-29-2009, 08:03 AM
I had a stock crank (cut 10/10) and stock rods (ARP bolts) with TRW pistons in a 406. It was making just shy of 500HP. I ran it for a few seasons and it saw a lot of street miles. I sold it to a guy who continued to run it and then put a plate system to it. I think the key is prep and assembly. The machine shop that built the short block only does race engines (lots of 7 and 8 second cars). Even if you buy the Scat crank, have a good shop check things over and assemble the short block.
ZONES89RS
04-29-2009, 02:18 PM
I will tell you like this, if you are going over 600 HP, dont use one, if you will stay under 600, you should be fine as long as you are doing a lot of street driving and rare track use. Nitrous will eventually break it. Opt for a cheap forged crank, a 5140/4130 piece should be fine for you. Can be had for 380 or so, then there is the delima of spending a mere 100$ extra and get a forged 4340 unit that will last you basically forever.
ZONES89RS
04-29-2009, 02:19 PM
Not to mention, i hope you are using decent rods.
D79
04-29-2009, 02:26 PM
rods are strong h beams
where can i get a forged crank for 380? everywhere i look is 600+
kenSS
04-29-2009, 06:46 PM
competition products sells cheaper forged cranks for around 380.
ZONES89RS
04-29-2009, 07:46 PM
Ding!
(not supposed to mention it).
D79
04-29-2009, 10:42 PM
holy hell!?
is this real?
why cant you mention it zone?
ZONES89RS
04-30-2009, 02:38 AM
Well, they are not a sponsor here, so i really am not supposed to let Ken mention it, BUT, since none of our other sponsors carry THAT particular crankshaft, i can let it slide.
kenSS
04-30-2009, 06:37 PM
My bad Zone, did not know that. I apologize.
D79
05-01-2009, 01:02 AM
thanks everybody
