Shawn @ VA Speed
05-10-2009, 08:41 PM
After months of design work,we are proud to bring to you our LS main support system.This is a must for high hp LS engines.Through Finite Element Analysis and computer modeling we have designed the strongest possible way to reinforce the main area of the Ls engine block.CNC machined from precision ground steel plate it will clear 4'' stroke with no modifications.Due to the fact that this support locks into the pan rails of the block,the block must be machined for ever thing to fit properly.
Available for all LS blocks with wet or dry sump oiling.The support system with all block machining,including line boring and main stud set will sell for $1400.00.
Give us a call and get yours today
Dry sump support shown
http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures4-08-09031.jpg
http://i256.photobucket.com/albums/hh190/twinturboz28camaro/newpictures4-08-09033.jpg
