10 Second Club - M6 What clutch's are you running?
GR8GAME
05-15-2009, 01:04 AM
I'm only trapping 120 right now but I'm getting closer to my goal.
I would like to know what clutch you guys in the 10's are running and how they are holding up. I am in the market for a new one.
Greenthumb LS1
05-15-2009, 02:01 AM
Ive been through 3 rps single disks that i got from keith but i just put the textralia Z grip in 2 months ago and it shits all over the rps... I did that and the tick master and it feels like a whole different car. Got with the Textralia fro sure....
GR8GAME
05-15-2009, 10:53 AM
Damn Jason, you're everywhere. How much did that clutch run you? I was considering the Monster, but they aren't really proven yet. I do want to get the tick master tho.
Greenthumb LS1
05-15-2009, 01:32 PM
Its $980 with the arp flywheel bolts and $350 for the tick master...
GR8GAME
05-20-2009, 02:11 PM
Anyone in the 10's have input?
Super Speed
05-20-2009, 03:06 PM
I'll help you out a little
http://www.ls1tech.com/forums/manual-transmission/809101-fastest-six-speed-list.html
yellowbird1232
05-20-2009, 03:56 PM
10.68 @ 131 1.57 60 with a street twin.
021less
05-21-2009, 10:50 AM
i'm running a tdp clutch, only got about 10 passes on it so far, but it grabs 100x's better than an ls7 i can tell you that. ran a 10.7@ 128. stock hydro's and stock t56.
mulalleybs
05-22-2009, 11:32 PM
SPEC stage 3+
studderin
05-24-2009, 11:19 AM
ram powergrip HD, aka. the 910 single disk
Sluggish
05-24-2009, 01:04 PM
10.61 @ 131 w/ 1.56 60ft with a Mcleod street twin and a adjustable master. The car drives 10x better than it did with a Spec 3+.
Mr. Bungle
05-28-2009, 08:10 PM
Spec 5 but it's kinda harsh on the street.
mulalleybs
05-28-2009, 08:30 PM
Why would you use a Spec 5 if your car is an 11 sec car?
ATLSS
05-28-2009, 10:15 PM
Horse shit. The Monster will get the job done man. Hands down.
And they are cheaper than the twin setups that some have last only 5k miles...
If I spent $1,000 + for a clutch that last 5k miles I would kill someone....
Monster/Tick hands down man....
I have 11.2X-11.3Xs in my car easy with NO weight reduction... I can take seats out and run less fuel for the 10.99.... and I'm running the Monster Level 3... LOVE it.....
spaz1
05-28-2009, 11:45 PM
Get the Mcleod RST
t
silverta00
06-01-2009, 06:54 PM
I ran a McLeod on my t/a with a 150 shot off the line. Ran a 10.80. Never had any problems with this clutch at all. It took tons of abuse too.
TransAm2002
06-01-2009, 08:28 PM
10.71 @ 128.65 with a Textrailia single disc Z-grip. It has been on my car over a year and still working great and I am not easy on stuff. It is also my daily driver and I race it everywhere. :) Probably at least a 100 passes on it. My car makes 580/670.
03 BUSA
06-01-2009, 09:25 PM
Spec Super Twin here with 0 issues.
1BADAIR
I used a spec III x-pad until last year. it had 20+kmiles and tons of passes at right around 4000lbs.It was enough to break my CCI driveshaft and 12 bolt but it started slipping once I was able to get the car to hook leaving at 6200
I just installed a mcleod street twin but something isn't right . Have to remove it and check things out. Kinda mad cause it only has 100 miles on it but I don't want to hurt it so its coming out this week. From what Billy says it has too much clearance between the first disk and the floater
SPEEDYws6
06-01-2009, 10:27 PM
10.02 @ 136 with a tex oz700. Lots of track passes and great street
ablility.
02SOMWS6
06-02-2009, 01:45 AM
10.5 @130 with a 1.45 60 ft. with a old ass spec 3I puck style clutch. Last time the car was on a dyno it slipped thought the clutch was going. since then car pulled 8 passes all in the 1.4 range then blew my gears apart in my 12 bolt. wish they still made this clutch. Mine is still in. With the changes I made the car should be in the 9's this fall. That will be the real test for this clutch
david vericker
06-02-2009, 06:34 PM
You got that right!! 10.57@138 w/ 1.68 60' :D
BADD SS
06-05-2009, 04:38 PM
I only ran an 11.1 last time but I'' definately be deep in the tens next time out with my latest changes, Im running a monster stage 3 and love it, pulled a couple 1.54's out of it and blew my 12 bolt to pieces...
ARCTIC '00
06-05-2009, 07:01 PM
RAM VDS 900 Variable Diaphram Clutch/Steel Flywheel. Excellent street manners, no issues.
Super Speed
06-05-2009, 08:28 PM
How do you like the clutch so far?
BADD SS
06-05-2009, 08:40 PM
It's great! Lighter pedal then my ram, took alot of hot lapping without a sweat at a track rental, 10 passes...
Gauge
06-08-2009, 11:57 AM
McLeod RXT street twin here... 10.96 @ 126 w/ a 1.58 60'
The clutch drives like a dream on the street, and it grips like mad at the track. It's stinking really bad after each run, but I may have oil on the clutch because my rear main is hosed and my PCV is inadequate I think.
purdueranger
06-08-2009, 02:00 PM
Tex OZ700 Z grip here.
LS1RedZ
06-08-2009, 03:43 PM
Spec 4+ w/ solid hub here. Car makes 683rwhp. Its holding just fine.
