Stereo & Electronics - gonna wire up an amp to stock monsoon system
steelsnow
11-04-2003, 07:13 PM
does anyone have a link to someone doing this? i have read the stuff at www.fbodyaudio.com but i like to look at pictures. its a lot eaiser for me.
Brains
11-04-2003, 07:32 PM
Take a look at the stuff I posted on http://www.houston-f-body.org in the tech section... should have what you need...
BigDaddyZ28
11-07-2003, 07:00 AM
I am curious about this one myself. If I find anything useful I will forward it to you...
I checked the Houston f-body site, and I did not find JACK pertaining to an amp install on the Monsoon.
James
steelsnow
11-07-2003, 10:09 AM
yea, all i found was wiring diagrams and stuff. anyone got pictures of the wire run from the battery to the back of the car?
Jamie99TA
12-03-2003, 02:32 AM
I'm planning on adding a amp and sub box too. Which wires did you splice into for the line level converter? I think the sub output wires of the monsoon amp would be the best place to connect the line converter because I think the amp has a crossover built into it. I got the PAC SNI-35 which works from 2-40 watts rms so hopefully the amp output line is 40watts or less. Does anybody know if this will work ok?
It should be a great improvement over the head units power
firebirdude
12-03-2003, 02:38 PM
All you need is the PAC OEM1. It simply plugs directly into the headunit's harness and gives you RCAs. No splicing needed. Run the RCAs to the rear of the car and hook up the amp as you would with any other car.
To run the power wire through the firewall, use the hole behind the PCM. It's VERY easy. Simply unbolt the two bolts holding the PCM (10mm?) and move it aside. Then you'll see a large rubber grommit with a few wires going through it. You can squeeze any size wire through there. I ran my 1/0awg through there. Come out undernearth the glove box and right where the carpet starts. Perfect.
