Convertible Vehicles - Top issue
t/afrom504
05-22-2009, 01:29 PM
Ok my top goes down but not up. I checked my fluid and its really low. I know its common sense but just be sure, do I need to fill it back up with fluid in order for it to work?
GR8RYD
05-22-2009, 02:17 PM
That's where I would start. I think there is a sticky about doing it.
t/afrom504
05-23-2009, 07:32 PM
I cant seem to find a quart of this fluid...only 5 gallons of it. I searched and found that brake fluid or ATF would work, is this true?
Bajapat
05-26-2009, 09:49 AM
I got mine a pep boys
t/afrom504
05-27-2009, 11:26 AM
Well I filled it back up now it only goes up and down sometimes and barely that. Im beginning to think that the motor is out. I tried banging on it, then it would go halfway up then stop...whats next???
LS1Z28
06-02-2009, 10:21 AM
Sure that will work if you want to replace the pump and rams. GM sent out a TSB to the dealers back in 1999 USE only Mineral oil.You can find it at any drug store or supermarket.
alasad
06-18-2009, 03:18 AM
I followed advice on other posts and used mineral oil bought at a drug store. Inexpensive and easy to fill. There is a resovoir adjacent to the vert motor. Used it last year and the motor works good. Tip; whenver I decided to take the top down, I unlatch it and give the top a starting push. I think this may prolong the vert motor. Hope this helps.
BigT2002
06-18-2009, 04:12 AM
get it fixed??
t/afrom504
06-21-2009, 01:32 PM
not yet...havent had any time but I may do it today
t/afrom504
06-26-2009, 07:18 PM
WELL i finally found the problem...it didnt want to go back up only because I put it to far down. But when going back up it moves SLLLOWWW....maybe the mineral oil will speed it up some I hope...I'll see
proporio
06-28-2009, 01:51 PM
Bang on it harder--use a bigger hammer:punch:
motor might be going bad
