Stereo & Electronics - alternator plug diagram?? wires cut..HELP!
Johnnystock
05-22-2009, 06:45 PM
I thought my alternator was bad but when I removed it, I noticed that theres is 2 cutted wire on 4 that are going in the alternator plug!!!
I've checked the car's wire diagram and its causing the check gages light to flash...
I want to re-wire em but I dont know where theyre going to!!
anybody has a clue!!???
spaz1
05-22-2009, 06:51 PM
What year? 98 has the red big wire bolted on and then a brown smaller wire in the plug.
Johnnystock
05-22-2009, 10:16 PM
well, after a search, I found out that the plug has 4 pins and only one wire coming out, normally..But mine 3 grey wires were attached loose.
I installed it this way and the flashing check gages is gone and the voltage instability too.
sroach20
05-23-2009, 10:46 AM
the altenator plug is one wire going to the pcm.
