JasonShort
05-22-2009, 06:31 PM
SOLD Buyer will need to pick up or I can meet someone within a reasonable distance.
Moser 12 bolt out of my 97 Trans Am. This will fit 93-02 Camaro/Firebirds with 3-channel setups. The rear will come with the "LT1" style brake backing plates, so you'll just need to swap your "LS1" style ones over if you are using this rear in a LS1 car.
Here are the options:
-4.10 (or 4.11?) gears
-Eaton 800# posi
-chrome rear cover installed
-brand new aluminum TA cover w/stud kit available for an extra $100 to the buyer
-1350 yoke w/straps
-33 spline axles
I need a stock rear end in return. It can be junk as long as it rolls freely.
Looking for $1700 with a junk rear in return, or $1600 with a good rear (don't care what gears are in it).
I also have a Denny's "Nitrous Ready" driveshaft that was used with this rear (for use with T56 cars) available to the buyer for $250.
Located in Rochester, NY
Thanks!
Jason
-Eaton 800# posi
-1350 yoke w/straps
-33 spline axles
Thanks!
Jason
