Small Block & Big Block Chevy Specific - starting problems
View Full Version : starting problems
UpOnOne781
05-23-2009, 12:35 PM
Hey i got a sbc with a lt1 intake with megasquirt system on it. When I try to start it, it backfires inside the intake. I was thinking maybe the timing is off but im not sure why its doing this. Any suggestions??
blubyou02
05-23-2009, 04:23 PM
Isnt the LT1 intake different,if not is it leaking between the intake and head mating suface.
UpOnOne781
05-23-2009, 06:52 PM
yes it is different actually. But it can be modified to fit. i wasnt sure if it could be a vacuum leak or the timing. i will try nd check the manifold to see if it may be leaking. Since its igniting into the manifold would it more likely be the timing?? i appreciate any help thanks
UpOnOne781
05-23-2009, 09:21 PM
i figured it out, i dont want to even tell you what it was but i will lol...i somehow managed to put the distributor facing the exact opposite direction of the first piston at TDC. I made the proper adjustments, now its running pristine...Thanks for your help tho.
