Advanced Engineering Tech - Quick compression question
View Full Version : Quick compression question
lt1z93
05-23-2009, 02:58 PM
Stock LS2 shortblock
AFR 205s milled to 63cc
.040 Cometic 4.130 gasket
Does this put me around 11.3:1?
405HP_Z06
05-24-2009, 12:31 AM
http://www.andersonperformance.net/cr-lt1z93.jpg
lt1z93
05-24-2009, 08:38 PM
That is a bit higher than I thought it was. Still runs good on 93 but my DCR calculations are off if it really is 11.6:1
405HP_Z06
05-24-2009, 11:53 PM
The only variable is piston-to-deck height. I estimated based on blueprint specs, so if it's different let me know and I'll recalculate. Other than that, it is what it is.
lt1z93
05-25-2009, 12:44 AM
I don't know the exact spec, but if it is say -.006 instead of -.009 that would only be a difference of 11.56-11.61. Thanks for you help.
Big_Bird_WS6
06-30-2009, 11:50 AM
where did you get that chart.
Proxses
06-30-2009, 03:38 PM
These guys have all kinds of useful software.
http://performancetrends.com/Compression_Ratio_Calculator_V2.3.htm
405HP_Z06
06-30-2009, 04:18 PM
Performance Trends sure does have some great software and hardware tools. I own and use almost every piece of software they have. The above information was generated with Compression Ratio Calculator Plus v2.3.
If you want to check out some real awesome software look at Engine Analyzer Pro and Suspension Analyzer.
Big_Bird_WS6
07-01-2009, 01:07 PM
second how do i meausre my deck hight?
thanks
XtraCajunSS
07-01-2009, 07:31 PM
To accurately measure deck height, you will need a deck bridge with 2 dial indicators. If it is a stock shortblock, you are ~.007-.009 positive (out of the hole)
Shane
405HP_Z06
07-01-2009, 11:18 PM
thanks
Piston deck height or block deck height?
