Small Block & Big Block Chevy Specific - timing help please
View Full Version : timing help please
fbdy4life
05-25-2009, 08:39 PM
anyone know how to adjust timing on a tpi. i had to install a new cap and rotor and once i did that the car will not start. so i figure that i set the timing off during the process or something.
TooLateVTEC
05-26-2009, 04:29 PM
As long as you didnt remove the distributor or move it, the timing shouldnt have changed.
Theres a single brown (I think) wire that needs to be unplugged so that when you change the timing the ECM doesnt try to compensate for it. Should be towards the pass. side somewhere. That needs to be unhooked to change timing at all.
Make sure you have all the connectors plugged back in.
fast01
05-29-2009, 02:33 AM
As stupid as it may sound, make sure all of your wires are on the correct terminal and on it's proper plug. I was helping my buddy out at his shop one time and a guy had his Monte SS towed in because it wouldn't run. To make a long story short, all of his plug wires were off by 1. As stated above, if you didn't pull the distributor it should not have moved.
raped 95Z
05-29-2009, 08:10 AM
definatey make sure your wires are on in the correct orientation...i messed that up once and chased the probelm for a day like a retard...i felt pretty dumb after that one...but it happens right?
fbdy4life
05-29-2009, 01:29 PM
that it does. ill go ahead and check the wires though, but im pretty confident that they are in the right place cause they are all numbered. but its most def. worth a shot. ha then i can see how much of a retard i am.
fbdy4life
05-29-2009, 03:53 PM
ha ok go figure. i was indeed a retard. they were all off by one. starts right up and runs like a charm now. thanks guys for showing me how much of a tardo i am :)
fast01
05-30-2009, 04:24 PM
Everyone has a brain fart every now and then. We've all done it!
