tylergarceau
06-06-2009, 12:06 AM
I am selling a complete Cold Fusion nitrous wet kit 75-250 shot. This kit has been installed but NEVER used. It comes with 2 brackets and a big bottle, which i brought to a local shop where it was professionally painted gloss black. no scratches. Also all wires and hoses, Purge kit, toggle switch, purge switch. This kit is one of the safest made, its triggered off of the throttle response, it only works when you turn the toggle switch on and have the car floored, full throttle. I paid around $650 for this kit. It has the 75 shot right now, and if you choose to have a different solenoid you can get them anywhere and are VERY cheap. Also with it being a wet kit its more safe on the motor! you can install this kit on any car.
LS1/LT1 Wet Kit Parts
Purge kit
1 x 10lb Nitrous Oxide Bottle In blue
1 x Pair of steel powder coated Bottle brackets
1 x Nitrous Oxide Solenoid capable of 200hp gains
1 x Fuel Solenoid capable of 200hp gains
1 x 12 inch Blue stainless steel braided hose
1 x 12inch Red stainless steel braided hose 1 x 15 foot stainless steel braided hose (for bottle to solenoid)
1 x Pro Fogger Nozzle
1 x nozzle hold fitting
1 x 4an Bottle Nut
1 x wide open throttle switch (used to activate the system when at full acceleration)
1 x 20 inch stainless steel braided hose (from Schrader valve to fuel solenoid)
1 x fuel line adapter fitting
1 x nitrous oxide pressure gauge to go on your bottle 1 x dual solenoid mounting bracket
1 x pack of screws for mounting
1 x solenoid fitting to attach your fogger
2 x blue solenoid fittings to attach your bottle to solenoid and your solenoid to fogger
1 x 12 volt 40 amp relay with plug in harness
1 x arming switch
15 ft of 12 gauge wire
Im asking 450 obo
http://i141.photobucket.com/albums/r71/tygarceau/100_1713.jpg
Purge kit
1 x 4an Bottle Nut
1 x arming switch
Im asking 450 obo
