Stewart Leask
06-08-2009, 01:07 AM
ok for starters i'm going to post up the mods list of the motor that i'm dealing with in particular.
2000 f-body ls1
asa cam, .550 lift
beehive springs
oem lifters
manley pushrods
c5r timing chain
melling 10296
probe pistons
eagle rods
chevy mls hg
arp mains
clevite's "race" bearings
gto front sump pan setup
3qt. high pressure accusump with manual valve
thats about it as far as parts that could be related to my problem minus some of the valvetrain parts...
i'm gonna type this up the best i can but no promises this is gonna make sense...
stage 1 with my motor, it spun a bearing at a drift event in st. louis, i replaced bearings on track, spun the bearing(s) again. done for the weekend, time to go home.
get home and have it rebuilt, at this point i pull all the stops and use eagle rods/probe pistons/full MLS gasket setup/arp mains/melling 10296/rollmaster dual chain (previously installed)/ cam and springs. engine shop sends me spec sheet and its right on point with all the research i had done. mains are .0023/.0025 and rods are .0025/.0027.
now, this setup had problems from the get-go. the melling 10296 was nowhere NEAR close to fitting. we did the typical housing machining but it just wasn't close at all. if you trimmed the timing chain cover or the oil pump cover down enough to where it fit you'd either hit a passage or put a hole in the timing chain cover. this was 2 nights before an event, so of course we got creative. we took the new gear from the 10296 pump and put it in my old 10295 housing after having it precision machined down to the .0001" of the width of the old 95 gear. from there assembly went great as did startup. motor built pressure correctly and temps are good as were the hg seals, no mixing. However, when we went to do our break-in test drive i notice my oil pressure stumbling. it wasn't consistent, had nothing to do with temps...or gravity. it was when the motor saw load or a hard punch in 2nd or 3rd, oil pressure would stumble down to around 36 psi then catch right back up. it didn't seem to mind 1st gear so much, more-so 2nd and 3rd...i haven't gotten to rip on the car much beyond that. we figure, totally shitty non-detergent break-in oil was the cause, so...new synthetic oil and filter in...same business.
so we've put the car aside while i order a new pump to eliminate the possibility of the gear we milled down being faulty. ANOTHER 10296 and a single row c5r chain to guarantee its fitment. We put it together this weekend with all new gaskets and o'rings and got fresh oil in. same exact problem right off the bat. i'm so lost, this pump was primed properly and installed properly and torqued to spec. we were careful not to pinch the pickup tube o-ring, i pushed it in carefully by hand before i tightened the bolt. so we step back for a minute and look at the big picture. motors built to spec, new pump, problem CANT be internal. i was told when i very first built this car which sides were in/out on my canton filter relocation kits. never thinking to double check (since a reputable shop had told me) i just installed it how they said. turns out this was my configuration all along...
engine out to oil cooler in, oil cooler out to remote filter "out" port, accusump being fed off "in" port of remote filter and finally oil filter "in" going back to the engines "in" port
yeah, it was incredibly wrong, i know. so we figure from there lets redo the AN line configuration. I got it all 100% based on quadruple-checking canton's site. SAME THING. accusump is more responsive now, as-is oil pressure. but the numbers didn't change much. then i eliminated the oil cooler thinking it MUST have bearing pieces and break-in bearing material in it. that didn't change anything. then i eliminate the accusump and the remote filter, put an 04 gto filter right on the pan. again, this was with the thought process that my accusump is probably ruined from having 3 sessions of serious catastrophe's on it with unfiltered oil the whole time. we bumped the oil weight up as well and went to 20w-50. first time i went out to drive it, nothing! the defi's recorded remarkably responsive pressure with just a little stumbling (but i feel this is from the cars stiffness as my tach did it a tad as well). i finally decided its time to take the car for a bit longer of a test drive, about a mile and a half to be exact. got on it a little harder and drove a little faster/gave the car different conditions. everything seemed fine. but the problem is, now my cars doing the exact same thing! oil pressure dropping as i'm giving it a certain percentage of load. only...its doing it more now!
none of the oil has shown any signs of extreme wear or any bearing material minus the break-in oil change which had the usual amount. when we first noticed the psi drop issue we immediately went to mechanical gauge which reflected exactly what my defi gauge did, so i know thats exact. we are sourcing our oil pressure from the oem location with a remote mounted sensor being fed from a -4 AN line.
I need realistic answers, I've been checking my oil levels constantly, I've done all my tests with and without my accusump on. I don't have a podunk oem gauge sensor feeding some obdII reader, everythings been exact readings (minus the ability to datalog, only record and playback on my gauge setup). Please don't leave me with generic answers. I am going to TRIPLE check my oil pump pickup tube o-ring this weekend, but beyond that...everything not internal or bearing related has been checked to the best of my knowledge. I'm running out of ideas and I need more opinions towards this particular situation.
Thanks in advance for your help!
2000 f-body ls1
asa cam, .550 lift
beehive springs
oem lifters
manley pushrods
c5r timing chain
melling 10296
probe pistons
eagle rods
chevy mls hg
arp mains
