10 Second Club - Another will I hit 10's thread.....
fuzzyjk
06-12-2009, 07:50 PM
I am an autocross guy and new to straight track so here we go.....
94 Camaro Z28....Brand new stock shortblock (LT1), A4, milled LE heads, 227 Crane cam, 1.6rr, larger injectors (I think 30's), 3000 stall, 3.23 gears, 150 shot dry, LT headers, ORY, cut out, no cat, 16" drags with some weight reduction. Guessing Hp 360 to the ground (motor only) 510 with the juice (rwhp).
Will I make it?
021less
06-12-2009, 11:03 PM
what kind of suspension is under the car? should be close on the spray but you will have to 60' pretty good. try it is all you can do.
fuzzyjk
06-13-2009, 09:14 AM
Nothing other than stock suspension, what do you recommend? If I go 3.73 how much will that help in the quarter?
Sluggish
06-15-2009, 03:24 PM
Will I make it?
I don't think so. Also 30lb injectors aren't enough for a 150 dry shot. My stock 28lbs got max at around 410rwhp.
