Canadian Classifieds - Wanted - an LQ9 and a shop who'll do an engine swap
Mortayjas
06-16-2009, 11:50 AM
Looking to swap out my 5.3L, looking for an LQ9 or LS6. The newer the better. I am located in the Toronto/Barrie area.
molson
06-24-2009, 12:28 PM
Do it yourself.....Don't be lazy
:D
Mortayjas
06-24-2009, 01:37 PM
Would luv to bud........basically.......don't know how nor do I have the resources to......lol
wildta
06-24-2009, 04:35 PM
I don't think its worth it for you to go about it this way. Yor 5.3 is putting out about 300 hp, the LQ9 depending on stock cam is 345-400hp. You might be better off with a cam swap. Now if you were going to go with a bigger crank to give you a 408ci, then it might be worth it. what are your HP goals, how much can you afford ?
Mortayjas
06-25-2009, 01:05 PM
Well I'm hoping for something like 400 rwh and spending $3-5K.
molson
06-26-2009, 03:38 AM
I don't think it's about HP......
It's more about torque.
I wonder what a full size 4x4, ext. cab, long box tips the scales @ ?
tsench
06-26-2009, 11:44 PM
get your self turbo or supercharge easy 400 :D if u said u wanna spent 3-5k
Mortayjas
06-30-2009, 10:27 AM
You think that's a good idea on an engine pushing 300k?
augiedog77
06-30-2009, 11:58 PM
ext cab short box's are around 6000 lbs
augiedog77
07-01-2009, 12:01 AM
long as you have a good tune sure. Your tranny will probably go before the motor will ever pop.
Wanna buy a modded kenne bell 2.2 set up (allows the use of a air2water or air2air intercooler), even got a LPE GT2-3 cam that would work real nice with it :secret2:
