Stereo & Electronics - driver Side window doesn't work
SSTYCOON
11-10-2003, 09:31 PM
my driver side window will not go down. When you press the button, you hear a noise from under the dash, that my be normal though. The passenger side window works. What could be the problem?
thanks.
OctaneZ28
11-10-2003, 11:27 PM
Sounds like the ever-popular oh-so-infamous burnt out window motor.
Join the club!
Or it could be frozen (New England weather). Mine was this morning. It went down a 1/4in and that was it. I had to get out to use the toll booth this morning. As the day went on, it warmed up and started working. I think I need to lube up the mechanism. Maybe you are experienceing the same thing. Otherwise, like OctaneZ28 said, the motor is burnt.
--VIP1
SSTYCOON
11-11-2003, 08:29 PM
thanks, i'll look into it, and it better be the cold weather and not the motor! :bomb:
MrHughes919
11-16-2003, 09:59 PM
mines doing the same thing and that noise is coming from under the dash...you say it may be a burnt motor? mines only doing it intermittenly like every now and then...
SSTYCOON
11-18-2003, 08:40 PM
I still haven't bought a new window motor yet, I called PAceparts and they said it could be the driverside window module, thing i ask them if this device was bad would the passengers window work?, one guy at pace said yes, then another said no. So i still don't know whats going on, I hate to buy parts i don't need, well unless it Nitrious!
the passenger side will work, if the drivers side window module goes bad...
Ryan.
LS1Baron
11-21-2003, 09:40 AM
While you're at it, go ahead and replace both motors. It's easy to do. Buy your new window motor from AutoZone. They come with a lifetime replacement policy.
Are those Autozone window motors faster and more powerful than stock?
My windows are the slowest that I have ever used. A 2003 Hyundai Sonata LX that I rented (nice car actually) had better power windows.
--VIP1
LS1Baron
11-22-2003, 05:43 PM
Yes, they are. They are actually Siemens motors, and work very well.
Arent there 2 AZ motors? I read once where there were 2 motors, 1 fits and 1 doesnt. If u have a part # that would be cool. Thanks Bear
770Guy
12-10-2003, 11:27 AM
How the hell do you change the motor? I got my door panel off, and i cant even SEE my window motor haha.
TTT. 50 or 70. Which one is better?
Check this out:
http://shbox.com/1/4th_gen_tech1.html
There is an article about power windows in the "How To" section.
Here is another good link:
http://www.ls1tech.com/forums/showthread.php?t=77124&highlight=window+motor
-VIP1
