Small Block & Big Block Chevy Specific - 1997 vortec 350 power?
View Full Version : 1997 vortec 350 power?
5.0&5.0
06-22-2009, 05:20 PM
im shooping around for a motor for my iroc project..and i found this 97 vortec 350 out of a 2x4 suburban..i tried to serch it but its not working..can someone please tell me what kind of power these things made stock?
BeefTip
06-22-2009, 05:34 PM
255 or close too it at the crank, real good torque
5.0&5.0
06-22-2009, 05:53 PM
niccee.....did the 5.0 vortecs come with 97 suburban 2x4?
does anyone have the casting numbers for the block..so i can make sure its a 350 motor
thx bill
5.0&5.0
06-22-2009, 08:31 PM
nevermind on that last post lol...but were exactly is the block castings on these..on the back?
7.0 camaro
06-23-2009, 12:09 AM
the block numbers are the same as they always been. you can look on the side or on the back. they will actually say 5.0 or 5.7 on them. but the 350 is the one with a 080 for the last three. thats the most common. or look for an R at the 8th digit in the vin if its in the truck still.
BeefTip
06-23-2009, 08:33 AM
I would go ahead and replace the intake gasket if you use a vortec motor....if you are switching to carb then you would have to do that anyway.
mred
06-23-2009, 10:50 AM
the 350 blocks casting is 880. i built a 350 with a lt4 hot cam and a 2500 stall that bitch would run.
7.0 camaro
06-23-2009, 11:41 AM
hell your right. i dont know what i was thinking. its hard to remember all these numbers. 880 is right though.
5.0&5.0
06-23-2009, 03:14 PM
yea if i get this motor..im to go with a TPI set up with an edelbrock intake 24lb injectors..already have edel shortys/y pipe and 3.73 posi in it...the following mods would be a 2500 stall and edel TPI runners
this thing should be a torque monster with a tpi right guys?
thx for your help guys
7.0 camaro
06-23-2009, 04:21 PM
not a big fan of the tpi. but it should feel better than a 305
BeefTip
06-23-2009, 04:29 PM
why not just a good holley 750 and swap the intake out to a vortec-carb intake...like a rpm air gap or something.
7.0 camaro
06-23-2009, 05:10 PM
the tpi is ok. but im not too sure on that "conversion" intake. its only rated to 5500. i would at least want 2500 to 6-6300.
5.0&5.0
06-23-2009, 05:38 PM
ehh i kinda like the tpi(its not TOO bad)...but with 305 i can never spin the tires from a roll or anything even with 3.73s(it will chirp somtimes tho)...its actually boring to drive bc of that...i jus wanna go from a slow roll like 5mph mash the gas and spin those fukkers..its anoying...im hoping a 350 vortec tpi with a 2500 stall will be able to do that
Bowtie_Aaron
06-23-2009, 06:24 PM
yeah 880 casting number is on the both sides of the block between the freez out plugs, and on the driver side rear of the block on the pad that the trans attaches to.
they are 1pc rear seal, roller cam motors.
you will need a special vortec tpi lower intake. i think edelbrock makes them. they are like 450 bucks though.
you can pick up air gap intakes real cheap for around 50-100 used.
factory rated at 260hp, 325-350tq or something like that. stock they run real strong.
i have a vortec block in my chevelle. has a voodo roller cam in it. you can use lt1 cams just have to push the down pin in.
if you plan to cam the motor, you must cut the spring pockets and retainer guides as the factory config is only good to .450ish lift.
good luck.
aaron
mred
06-25-2009, 08:49 AM
he would be "SO" much "HAPPIER"
1redta
06-25-2009, 09:21 AM
stealth ram FTW
BeefTip
06-25-2009, 11:38 AM
:confused:
mred
06-28-2009, 09:10 AM
:confused: you dont remember what say in your post do you?:twak:
BeefTip
06-30-2009, 12:23 AM
yeah i do, i just have no idea what your quotations meant retard
mred
07-02-2009, 11:45 PM
Happiness is a state of mind or feeling such as contentment, satisfaction, pleasure, or joy. A variety of philosophical, religious, psychological and biological approaches have been taken to defining happiness and identifying its sources.
DUMBASS:gtfo:
TAtoad
07-03-2009, 02:05 AM
i'm with this guy. i also dont see what the quotations were hinting at
mred
07-04-2009, 07:27 AM
thats because your a "TOAD":D
BeefTip
07-04-2009, 09:33 AM
i think you are alone on this one:engarde:
moge11
07-15-2009, 04:43 PM
Dude said "Why dont u go with a Holley and an AirGap instead of the TPI?"...then the other guy said "He would be SO much HAPPIER!"....How hard is that for you guys to understand????!!! And Napolean Dynamite says, "God, Idiots".
He would would be SO much HAPPIER with a Holley and an Airgap then he would be with TPI...As in he would make about 50 more horsepower above 5K.
1redta
07-15-2009, 04:56 PM
the stock vortec computer will only rev to 5900
a tune port set up on these motors ( vortec )will torque almost like a BB or diesel but will suffer on the top end probally fall on its face about 4800
the lt1 intake should be a good all around intake for this also but it all depends what this is going in. if this is for a heavy vehicle, I'd stroke it with a hot cam 2500 stall with a lt1 intake or stealth ram.
BeefTip
07-15-2009, 10:54 PM
A sphincter says what?....
squee
07-16-2009, 12:36 AM
We're not worthy!!! We're not worthy!!!
moge11
07-16-2009, 10:51 AM
obviously NOT since u cant comprehend something so obvious...Its was cute of you to stand up for each other....But that just pointed out that ur BOTH slow readers...
BeefTip
07-16-2009, 01:16 PM
did you just call me cute?:gay:
squee
07-16-2009, 01:20 PM
Dude, are you that fucking stupid? Your the one thats the slow reader obviously cause that was my first post in this thread...
