Stereo & Electronics - Finished my Double DIN for my DNX 7140
BRD-PREY
06-30-2009, 01:04 AM
I want to give all of you guys on LS1TECH a big thanks. I got the ideas and info from y'all. Special thanks to whitebird00.
I will post step by step photos and instructions soon, tired tonight. I will probably make another one because I had 2 stock bezels. I made a jig, I think I can knock it pretty fast now.
Please let me know what you think.
Ed
This is the mount
http://i689.photobucket.com/albums/vv257/BRD-PREY/Mountfront.jpg
This is the bezel
http://i689.photobucket.com/albums/vv257/BRD-PREY/bezel.jpg
The top and bottom needed to be slightly larger than the opening to allow the angles that the screen goes through.
http://i689.photobucket.com/albums/vv257/BRD-PREY/bezelangle3.jpg
http://i689.photobucket.com/albums/vv257/BRD-PREY/bezelangle.jpg
http://i689.photobucket.com/albums/vv257/BRD-PREY/bezelangle5.jpg
The paint was the texture paint from walmart. I got the idea from someone here, but they never mentioned the colors. I bought the grey because it had more texture. I new it was a little too much. So I bought the black for the right color and the texture is too small but it fills in the larger grey texture and kind is a happy medium.
http://i689.photobucket.com/albums/vv257/BRD-PREY/Paint.jpg
Ed
naperws6
06-30-2009, 01:22 AM
Nice work looks awsome!!! In the first pic where did you get the bracket?????
HitmanLS1
06-30-2009, 02:20 AM
Looks good man
BRD-PREY
06-30-2009, 06:43 AM
I made the bracket, 16ga sheet metal, I tigged up. I will post directions and lessons learned soon. I will probably make a second bracket to go with the second bezel I make and get rid of them on here.
Thanks for the props, I'm really happy with how it came out, I'm fussy, which sometimes is major expense and pain in the ass!
ed
WhiteBird00
06-30-2009, 09:22 AM
Very nicely done! As I've seen before, your work is well finished with great attention to detail. I especially like the support bracket. My only concern is that you trimmed the side panels of the support so as not to block the cooling fan on the side at the back of the head unit?
BRD-PREY
06-30-2009, 10:32 AM
Owh? It only goes so far back and I remember the fan is in the back!! Does it have air intakes along the side???
Ed
WhiteBird00
06-30-2009, 11:04 AM
Maybe the 7140 chassis is a little different but the 5120 has the fan on the left side near the back - I remember it was one of the things I preferred compared to the Pioneer (with its fan on the back) because of the limited clearance behind the HU when installed.
If the 7140 has the fan on the back then please ignore my earlier comment. :emb:
BRD-PREY
06-30-2009, 03:04 PM
I know the fan is in the back but there might be side vents. I though there was a lot of room in the back.
I notice and now I can't find, didn't you mention you figured out how to display the background picture completely. Basically hide the controls and such.
Ed
naperws6
06-30-2009, 07:02 PM
I'm about to install my pioneer d3 and need a bracket acn you pm info $?
If you can cut two pieces of metal, make two bends, and drill some holes, you can make your own brackets. It really is that easy. I made my own. You don't need a shelf like he did. His bracket/shelf is more complicated because he needed more clearance and the stock shelf broke so his bracket incorporates a new shelf.
Here is where he talks about it:
http://www.ls1tech.com/forums/stereo-electronics/1131630-double-din-mount.html
Here is my write-up for installing a Pioneer AVIC-D3:
http://www.ls1tech.com/forums/stereo-electronics/926597-pioneer-avic-d3-installed.html
I made my own simple brackets.
Here is a pic of the brakets:
http://www.fadingarrow.com/images/AVIC-D3_NoBezel--(small).jpg
BRD-PREY
06-30-2009, 08:56 PM
Thats why I thanked everybody, no sense in re-inventing the wheel.
I totally agree, I always over engineer the shit out of everything! If your shelf stays intact those style brackets were what I was going to use.
A side benefit of my shelf busting is, I think my unit is slightly(very slightly) lower which helps with the bezel.
PS I have this jig theory in mind. Whats the opinion is there a need for a bracket+double din bezel combo for say $100.00 with bezel core and $125.00 without. I figure a week to 10 days tops for turn around. Just spitting out the idea.
But my thoughts are the bezel would be say .005 " oversized/undersized(?) and the installer would flat file to fit. The fact their is small variations between location and cars that would be the best way for it to be high quality fit. If one is careful filing doesn't even effect the front finish.
Opps top secret jig!!! Can you tell I found the benefit of photo bucket. I put photos on everything, so annoying.
http://i689.photobucket.com/albums/vv257/BRD-PREY/DSC01750.jpg
Ed
transambandit
06-30-2009, 09:02 PM
looks clean, i was thinking bout using the bedliner stuff for my bezel but i ended up wrapping it in vinyl, turned out pretty good.
WhiteBird00
06-30-2009, 09:22 PM
EdWhen you have a music source playing, press and hold the top left corner of the screen where it says the source name. After a few seconds the controls will disappear leaving only the background image.
Detoxx03
07-02-2009, 12:39 PM
I need a bracket
1badWS6
07-02-2009, 04:19 PM
What's the depth on that unit?
Never mind ... it's 6 and 1/4".
1badWS6
07-03-2009, 11:33 PM
So I looked through both threads and I didn't see this anywhere. But how does that bracket mount above the shelf?
BRD-PREY
07-04-2009, 01:11 AM
Not sure I understand rhe question, the bracket screw into the stock mounting holes.
Ed
1badWS6
07-04-2009, 10:38 AM
So how is the HU secured to the bracket? Is there tabs on the unit that hold it in place like a regular dash kit?
1badWS6
07-04-2009, 10:39 AM
Is it those holes on the right and left side to screw some screws in?
BRD-PREY
07-05-2009, 11:03 PM
The factory mount holes for the radio. 2 on the left and one on the right.
ed
BRD-PREY
07-05-2009, 11:05 PM
Opps, yea I drilled holes and the unit has multiple mount holes and I put 4 allen head metric screws in to the holes in the unit through the bracket. You just have to be careful as they can only extend 6mm into the unit.
1badWS6
07-06-2009, 10:42 AM
Got it ...my girl can get a good deal on the Kenwoods right now and I'm looking into a double din now. Or I might just stick with another flip out. How do you like your Kenwood?
BRD-PREY
07-06-2009, 11:11 AM
I love it, it is actually better than the specs. It has a 5 band eq. and its got an adjustable DSP plus it has a built in 24/18/12/6 db crossover thats full frequency programmable.
Besides the flush factory looks rock.
Ed
The Doulbe din install was easier than I expected!
