Stereo & Electronics - Sub box dimensions?
View Full Version : Sub box dimensions?
No Juice
11-13-2003, 05:43 PM
Anyone have the dimensions for the 10" Sub box that fits in side on the drivers side?
I'm planning on making my own plexiglass box
Thanks
samuraixv
11-14-2003, 01:01 AM
what you can do is use aluminum foil put it in side and mold it to the walls of the car and sprey with a starch or somthing like that to hold the curves then you can use that as a mold for your box then all you will need to design is the face
No Juice
11-18-2003, 06:18 PM
Ttt.....
Silver98camss
11-19-2003, 01:28 PM
The dimensions are not a fixed number. You must make sure that your subwoofer will have the proper amount of air space & that the depth of the sub your using will fit. I also believe subthump.com has their enclosure dimensions listed on their site. But as I said every enclosure is different depending on the sub your using's specifications.
good luck
