Tools & Fabrication - first time header builder some helpfull hints?
73 nova guy
07-06-2009, 10:59 PM
well tomorrow i will be beginning my header setup in my 73 nova tom and just wanted some helpful hints on building them. i fixed the collector today i figure i will start with the farthest cylinder port from the collector and work my way in to the closest port.
so any helpful hints. like using a template or measuring would help
jg04222
07-07-2009, 10:11 AM
Look at burns stainless' website...they have a section about building headers. it has some pretty good information in there.
dpd069
07-08-2009, 06:22 PM
I've built a few sets for cars and airplanes. Here are some of my tricks-
-Get the flanges from GM. You can't get them water-jet cut for less than GM charges
-Put the collector where you want it and then start building the header between the flange and the collector.
-Make a jig to cut the mandrels. I made one to fit my bandsaw that would cut the tube square at any angle.
-Cut your bends square (see note above) You can also use a piece of paper and a marker to make a mark and cut them square, but it is kind of tedious
-An inexpensive wood bandsaw can be converted to cut metal by installing a jack shaft to slow it down. The old iron frame ones are the best to convert. I have an old cast-iron Delta that I've got about $100 in. Get a bimetal blade for it
-Buy mandrel bends with several different radii (sp?) to ease fabrication.
-Use packing tape to hold the cut pieces together before you weld them so you can do trial fits
-Buy the tube sleeves that Hooker sells to align each pipe joint together. You don't have to back-purge or use a filler rod and it makes a very clean tig weld
-Tack with the MIG and weld with the TIG
-If you can't afford a slip on collector (and who can) have a four-leaf clover design water jet cut with a material width of about 3/16 to 1/4" then weld the tubes to that, then the collector to that. It is almost impossible to get the collector to seal up without doing this, and welding inside the collector is a huge pain in the ass. If you think your motor is so sh*t-hot that one of those pointy thingys in the flow path to help the dump loss into the collector would make a difference, this techniqe makes it really easy to weld one on.
-Tig weld the tube joints. Mig weld the tubes to the flange to create a generous weld fillet - you will have a lot less cracking problems.
-leak check each completed tube before you weld them into the collector and flange. An old bicycle inner tube cut in half and hooked on to each end of the individual tube with a hose clamp works well. Pressurize with shop air through the bicycle stem. A little dish soap in a spray bottle works well for finding pinholes
-If you weld an O2 boss on, make sure the sensor clears other components (don't ask how I know)
-The Techline coatings work pretty good and are much cheaper than ceramic coatings. Cure them on the engine, not in your significant other's oven, or you will have a really big mess on your hands (again, don't ask me how I know)
If you want to see some photos, let me know and I'll gin some up.
Phil
73 nova guy
07-09-2009, 12:01 AM
Phil
wow thanks phil..
this is what i came up with for the drivers side. now i didn't final weld it yet i got one little hole to fill in the rear tube got a little over zealous with the tig pedal.
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo10.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo7-1.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo9-1.jpg
99345hp
07-11-2009, 11:57 AM
not too bad so far, but I would have tried to stay a little farther away from the brake master. That is going to be some serious heat right next to it.
bgblockelcamino
07-11-2009, 01:48 PM
ran into same problem with brake booster, have either made a heat sheild or converted to hydroboost off of newer mustang GTs get the whole setup for 100-150 bucks.
bgblockelcamino
07-11-2009, 01:49 PM
looks really good though. just takes time and trial and error till you find something that works
73 nova guy
07-12-2009, 01:56 AM
well i plan to coat these and then wrap them with header wrap. if i must make a heat shield i will that's not a problem. here is the final product
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo11.jpg
http://i65.photobucket.com/albums/h232/rackerman62583/Nova%20ls1%20conversion/photo12.jpg i still need to cut the collector down and fit the vband on.
Pauls325
07-13-2009, 04:46 PM
im getting ready to build some headers for the GXP this coming winter and am looking for any tips or tricks you guys have whare to get tubing, figuring out primary size, welding tips, and just other things to overlook. this thread has been helpfull so far
GXP comes with an ls4 makes 303 hp stock at the flywheel with a fairly broad curve on it ill put up my stock dyno i was thinking a 1 3/4 or 1 7/8 primaries but traction is an issue with these cars so losing some torque down low for high end power would not be all bad
http://i343.photobucket.com/albums/o478/Pauls325/dynogood.jpg
thanks guys
Stampede4ever
07-14-2009, 02:59 PM
dpd069: Can you post some Pics?
Thanks.
dpd069
07-15-2009, 07:06 PM
I will take some tonight and post them up. I take it you want detail shots?
Stampede4ever
07-15-2009, 07:41 PM
Yes sir, like to see how the collector is welded on, and your fixture. Also what does the Techline coating look like?
Thanks Stampede.
dpd069
07-15-2009, 09:38 PM
Here is a shot of the collector.
Imagine a four leaf clover cut-out in .25" steel, then a hole punched in the middle of each leaf. Insert the primary tubes inside each of these holes and weld from the inside after trimming the primaries flush.
Slip the collector on over the clover shape and weld all around - no leaks
This is what black Techline looks like. You can get other colors too.
(Sorry, the car hasn't been cleaned from the last trip out)
http://i866.photobucket.com/albums/ab221/e015475/Headers003.jpg
I like vbands. These I salvaged from a junkyard that had a bunch from a food processing facility- I jet cut some soft copper sheet to use as gaskets and no exhaust leaks.
http://i866.photobucket.com/albums/ab221/e015475/Headers004.jpg
This is a GM header flange. Note the wide fillet on the flange to tube
http://i866.photobucket.com/albums/ab221/e015475/Headers005.jpg
This is a top down look at the driver's side header. I tried to make them about the 33" primary tube length and equal volume - they are within about 5-10% but it probably doesn't make any difference with the turbo
http://i866.photobucket.com/albums/ab221/e015475/Headers006.jpg
This is a view of the whole thing and the turbo
http://i866.photobucket.com/albums/ab221/e015475/Headers007.jpg
This a view from the ass end. The turbo is suspended from the chassis so that the header system could be as light as possible. (the motor mounts are solid) I've beat the hell out of it for three seasons now and no problems so far.
All together I have about $240 in this set, including the water jet pieces but not the coating. It is all mild steel and it isn't coated inside (everytime it starts I make sure it warms up and there is no water in the tubes)
Let me know if there are any more details you'd like to see
dpd069
07-15-2009, 09:42 PM
I don't know why but the last image didn't post, so here it is
http://i866.photobucket.com/albums/ab221/e015475/Headers002.jpg
Oh and it is a sand car, if you hadn't caught that.
dpd069
07-15-2009, 09:56 PM
And one more thing you asked about..............
There is no fixture per-se.
I fab'd the bifurcated turbo secondary tube first, then hung it in the chassis. Then I trimmed the collectors and v-banded them to the turbo secondary pipe. They could rotate around the center axis, but the flange location was fixed.
Put the GM flange on the motor, then built the primaries to connect the two.
The 2-1 turbo tube is symetrical, as are the header primary tubes from side to side. The cylinder head stagger front to rear is taken up by a longer collector secondary on one side
daryn c
08-06-2009, 11:02 PM
i hope you flowed argon through the pipe as you welded it
dpd069
08-07-2009, 05:45 PM
No I didn't.
I believe I mentioned that I used some alignment rings that Holley sells that puts a thin backup ring inside the tube and a little burn-down ring between the joint. No filler is required and no back gas either. Makes a nice joint.
If anybody is interested I'll get the part number for the rings.
Phil
kcs387
08-07-2009, 10:10 PM
The headers look good. Nice job.
mebuildit
08-17-2009, 09:39 AM
No I didn't.
Phil
Can you get a link to those alignment rings for us?
Plus can someone show how they "back gas" for welding tubing?
Thanks in advance
dpd069
08-17-2009, 11:11 PM
Here's the link the alignment rings I've used-
http://www.holley.com/types/Miscellaneous%20Components.asp
I think I last bought them from Jegs or Summit.
You mentioned "back gas" but what I think you want to know about is "back purge", which is a technique of flowing argon behind the weld to prevent the backside of the weld from oxidizing.
To do it you need an argon regulator with two outlets - one to the tig and the other to the back of the work. (I suppose you could use two argon tanks too) Most people would tape up one end of the tube your welding and put a vent hole, then stuff the other end of the argon hose in the other end of the tube with a rag or tape, then fill it full of argon. It has to flow a little to keep the cavity full of argon while you weld.
Be sure that you do this in a well ventilated area - argon can cause you to suffocate if it displaces air that you breath. (the fumes will probably kill you first, but I just thought I'd warn you)
If you can reach the tacked weld joint, there is also a paste you can use as an alternative to back purging that effectively acts as a flux and keeps oxygen out of the weld. You might check with your local welding store.
Hope you found this helpful,
Phil
scrapecc
08-19-2009, 06:59 PM
John deere black (muffler paint) is another great header coating, it comes in a rattle can, lasts forever, and is available at any john deere dealer. A guy that builds high end hot rods turned me on to this and i have used it for anything i want flat black. It is awesome!!!!
Silverback
09-20-2009, 04:17 AM
Phil
Phil, can you give some details/pics of the jig/how you're doing this?
thanks
dpd069
09-20-2009, 09:47 PM
I'm cleaning my shop tonight and I will see if I can find it.
It is just scraps of wood, MDF and aluminum - nothing too fancy just a shop jig
Phil
dpd069
09-22-2009, 02:56 PM
I must have put it somewhere where I can't find it but let me see if I can describe it to you.
The jig positions the mandrel bend in the vertical bandsaw so that the blade always cuts normal to the surface of the mandrel bend.
It consists of two plates, the bottom one is MDF and the top one is .125 aluminum,
The bottom plate has a rail on the bottom that fits inside the guide grove on the table of the bandsaw so the fixture can be pushed through the bandsaw to make the cut.
The top plate is fastened to the bottom plate with one pin located at the center of the radius of the u-bend. There are blocks of wood that locate the u-bend such that its radius is centered over pin.
To get angle cuts the top plate is moved relative to the bottom plate and secured with a clamp. The mandrel bend is clamped to the assembly for a cut.
Hope this all makes sense. I will keep an eye out for the jig and post up pics if I find it.
Phil
RexDiablo
09-26-2009, 05:33 PM
Nice read as im doing my first header soon! Hard to find bends etc in Norway, so is there any good webshops where i can find both holley rings, bends, straights etc ? It would be easy to just order everything!
dpd069
09-26-2009, 08:40 PM
I think your best bet would be Jegs or Summit.
I believe I bought my last weld rings from one of them and they also sell mandrel bends, collectors and flanges.
Phil
