Jrmotorworks
07-10-2009, 08:54 AM
I'll try to make this as shot as possible, but its a long story. Here's what I have:
Alpine H/U
2 Rockford Power 500 amps
Infinity Perfect 12" sub
Diamond Audio components in front, nothing in rear.
So for years I've been dealing with a whine when I put the amps in. Not only does it whine, but it also pops when another electrical item is used such as brakes or turn signals. I've done numerous stereos and never had a problem. I installed for Best Buy for 5 years and never had one come back and I've tried everything on this car (94 T/A).
Over the time I've tried 4 different H/U (some for testing, others replaces) and it still makes the noise, so it shouldn't be that.
I've tried different amps, all with same whine and popping noise.
Ran new ground for H/U and amps, even tried running them to the same point in the car once, no change.
Ran a new power wire outside the car (for testing), no change.
Ran the RCA's down the middle of the car, not even tucked into anything just sitting there. That was the ONLY difference I ever saw. It made the noise quieter, but still there. I even recently bought new RCA's, double shielded and what not and tried them last night with the same result.
What gives??? I'm at my witts end with this damn thing. I'm about to build the system outside of the car and put on piece in at a time or something.
One thing I did try was I disconnected the RCA's at the amp and the sound went away. But my question here is, if the RCA is not plugged in, is the amp even sending anything to the speakers? If it does then I guess I can look at the H/U, but what else can I do? I've tried dedicated ground and power wire to the H/U. The ony thing I haven't run a dedicated wire for was the acc. wire for the deck to turn it on. Just thought of that, but would it have any affect?
Sorry for such a long post, but any ideas are greatly appreciated. It realy shouldn't be this damn difficult. I'm about to pull it all and put some gauges there, at least it would be USEFULL!!! lol. Thanks guys.
Alpine H/U
