Stereo & Electronics - Amp Question
View Full Version : Amp Question
Choppers
07-10-2009, 11:27 PM
How would this amp work with 2 of these 8' subs that I will provide the link for. Would it be to much not enough? Also anyone ever use power acoustik? I have have never used them before. Ya'lls thought will be helpful.
Amp:
http://www.crutchfield.com/S-g9nwwaS4XA8/p_026TS9604/Power-Acoustik-TS960-4.html
Subs I will have 2 of these:
http://cgi.ebay.com/RE-AUDIO-US-AMPS-REX8D4-PREMIUM-8-SUB-CAR-SUBWOOFER_W0QQitemZ290329835602QQcmdZViewItemQQptZ Car_Subwoofers_Enclosures?hash=item439901b852&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C 293%3A1%7C294%3A50
Engine_HP
07-11-2009, 01:20 AM
no they will not work together,
Choppers
07-11-2009, 08:48 AM
to much power?
Engine_HP
07-11-2009, 12:19 PM
to much power?
no,
this is a 4 channel amp when bridging it to 2 channel it will stable at 4 ohm,
the subs are dvc 4 ohm, when connecting them in parrallel the will produce 2 ohms load,
Choppers
07-11-2009, 03:48 PM
ok yea i think i am just going to save up for what i really want anyways.
Snootch
07-12-2009, 05:31 PM
You could use that amp with those speakers, but to power more than a pair of subs. You could wire each of those subwoofers voice coils in series so they are essentially 8 ohm subs, then wire both the subs in parallel so they present a 4 ohm load to the amp on channels 3-4 (bridged). Then use channels 1 & 2 to power your front speakers (front doors). Remember, If you will be using the factory deck you will need a line output converter as well as some RCA cables to connect to the signal input to the amp. Also, don't forget to buy a decent 8 gauge power wiring kit for the amp as well. You might want to check out Kee audio (sponsor) to see what they can do for you as well. --->
