Stereo & Electronics - Tweeter removal
View Full Version : Tweeter removal
slickone
07-12-2009, 10:56 AM
How the hell do you get the little metal clips off that hold the tweeter in without breaking off the plastic piece?
1998 T/A
Mr. CPG Trans Am
07-12-2009, 01:44 PM
front doors or rear pods, when i redid my rears i just drilled the pop rivit out. i will be starting doors this week i let you know what i find out.
KEE AUDIO
07-12-2009, 03:29 PM
Door tweeters are removed by undoing the phillips head screw and then prying a thin blade screw driver or other thing bladed tool between the magnet on the tweeter and the metal bracket. It will pop off then. GM screwed it in and put some adhesive there as well. I used a small chisel to remove mine way back when and it did well in getting between the bracket and the tweeter. One twist of the wrist and it popped off.
Mr. CPG Trans Am
07-13-2009, 06:51 AM
Thanks, That should help me a bit.
