Stereo & Electronics - remote window down with progressive unlock bypass????
moss_ws6
11-16-2003, 07:03 AM
I have seen it done and searched the site to find out how to do it, but can't find the information. I've found sites explaining how to get it to unlock both doors with one push of the button, but I need to know how to make the windows go down with the second push of the button. PLEASE HELP!!!
02slvrz28
11-18-2003, 12:03 AM
I am assuming that you are talking about the lock unlock feature of the factory remote. There is a way you can cut the passenger side door lock/unlock wires and tap them into the drivers side so they both lock and unlock at the sametime. Then you can use the second push of the button to do something else. You will need a window box that makes the window go down. You can buy them at any car audio shop that installs alarms. I believe DEI has one. And should be around $50. I have a remote start add on that is made for the same thing. Just never hooked it up and probably won't.
skytower31
11-24-2003, 04:00 PM
Check out this site. It uses the dei 530t. Works great!
http://www.p71interceptor.com/fourthgen/windowmodule/
