BIGBEAUTIFULDOLLP51
07-14-2009, 05:59 PM
Trying to take the crank bolt off...what puller should I rent (have a cheapie now)..thx
Kevin01Z28
07-15-2009, 02:35 AM
I assume your trying to remove the crank pulley? For that you just need a 3 jaw puller. Once you remove the crank bolt thread it back in the crank a few turns so the puller can have something to push against. A longer bolt would be ideal but i removed it without using one.
BIGBEAUTIFULDOLLP51
07-17-2009, 10:45 PM
Thanks Kevin...it worked!
